Yes, it does charge, I even used original charging cord. I asked local Hyundai office, will see.Never seen that, just the red light on the bottom...very strange.
Here is the page I found in the owners manual.
Does not show that light status.
Did it charge properly?
Not necessarily it can just be fault from the power supply(EVSE) or your main electrical supply or ground issue. I was able to trigger the Christmas tree effect using the OEM granny cable and portable generator. The 2K Yamaha inverter generator overloaded on 12 amp charge request and lit up the red charge port LED. I was able to resolve it by changing the EVSE pass through to 10 amps.This is a defect within the charge port ... the third time I've seen it reported and has become known as the 'seasonal lighting effect'. The dealer should have no issue with repairing it.
Does the red light blink or stay solid?Not necessarily it can just be fault from the power supply(EVSE) or your main electrical supply or ground issue. I was able to trigger the Christmas tree effect using the OEM granny cable and portable generator. The 2K Yamaha inverter generator overloaded on 12 amp charge request and lit up the red charge port LED. I was able to resolve it by changing the EVSE pass through to 10 amps.
I honestly can't remember, sorry.Does the red light blink or stay solid?
A portion of the ringed charging indicator is red instead of green while charging.Being colourblind I literally can't see the issue.
Thank you. I will never understand why red and green were/are chosen to represent so many things when 8% of men can't properly distinguish them. It's been especially bad since LEDs have gained so much traction.A portion of the ringed charging indicator is red instead of green while charging.
Don't feel left out. The majority of Led lighting has a poor CRI (color rendering index) rating :Thank you. I will never understand why red and green were/are chosen to represent so many things when 8% of men can't properly distinguish them. It's been especially bad since LEDs have gained so much traction.
I think this is the correct assessment. The docs show only three LED drivers and those are most likely RGB rather than by location on the ring.I think it's water ingress into the LED strip, as it tends to be the lower LEDs...
Thanks KiwiME for reminding me I have to do that as well as it is generally a wet environment here.I think this is the correct assessment. The docs show only three LED drivers and those are most likely RGB rather than by location on the ring.
I applied some clear silicone RTV at the edges of the LED ring in the hope it might help prevent this issue.
