I am starting this thread with my observation today.
The yellow light was on(the one between the H on the front badge) after 4+ hours of being parked.
I remember something in the manual that was an indicator of systems active in the vehicle, so when I got home I measured the 12V directly at the battery terminals and it was 12.36 V.
Put car in run mode and the voltage was 14.76, left on 15 minutes and rest voltage was 12.67.(Fluke 97 meter)
Excellent! The big battery charges the little one but still have to find the low and high threshold of when that takes place,
Have not used much of accessories so it seems a little early( 3 weeks ownership) for the 12 V battery to be that low.
I will monitor, but at least its comforting in the fact that if the voltage is low (indicated by the yellow light in the front badge) you can put into run mode with the electric brake on and top off the battery(no external battery maintainer required).
From previous ev experience I have found the minimum operating voltage without any software hic-ups is 12.6 V
