robxb
Dual climate is a lie.. everything merges together and it wastes energyA lack of dual climate zones is another one that will become an issue.
Sent from my SM-G930V using Inside EVs mobile app
That's not fair, the dash is paddedNo interior safety at all.
Agreed, it would be great if it weren't just radar/distance based, and actually "let off" when brake lights start appearing ahead of it. It leaves me stressed more than relaxed, to be honest, with my foot/ankle getting uncomfortable because I find it hovering over the brake pedal, just in case.it doesn't slow down enough for my comfort zone
There is a setting in the menus for how fast it accelerates on cruise control, check it outAgreed, the limitations of the system given the hardware provided.
It definitely takes too long to accelerate once the car ahead turns out of your lane
At what speed? It changes depending on speed.. At 100km/h, I feel like it's more than 100 feet. Might seem like that because it's hard to measure distance while moving.About 100 feet when on 4 bars.
Not sure where you drive, but here in Toronto, even when I leave it at setting 2, I have people trying their darndest to pass me and squeeze in front. Setting 3 or 4 I would definitely have drivers flashing their high-beams and maybe even honking!Why would someone use a lower setting?
No it isn't. When my wife is in the car, either I am freezing, or she is roasting. Our optimal settings are only about 4 degrees apart. With only a single zone we are back to the thermostat battles.
I would recommend she has her cool air and you close your vent, and if you are too cool, use your heated seat & steering wheel instead (if you have one). Using these heated devices is far more energy efficient than wasting the electricity to heat half the cabin while battling it out with the cooler side.
You just have to experiment with it in careful way for sure. Just always be alert. It works great in medium traffic I find especially on rural roads
One of my biggest pet peeves about it though, is that brake lights don't come on on regen 2, only on regen 3, and that the brake lights don't stay on when at a stop (unless you tap the brake and auto hold is on, for example).
Not true! Brake lights come on earlier. I always use Regen 2 and my brake lights come on ... [emoji6]
No idea, I heard that for the first time. [emoji2369]Where in the menu does it provided better acceleration on cruise
I will be checking those weep holes for proper draining function, are they located at the front or rear of the door bottoms?Nobody's mentioned this so far, at least in this thread...
You know how most car-door windows will sort of self-squeegee any water
off the outer surface when rolled down, because the outer weatherstrip rides
against the glass as it goes past? The Kona doesn't seem to do that, on any
of the windows, because there's a substantial gap between the glass and
the strip once the window starts moving down. It more or less closes when
the window is fully up, but not especially tightly and some amount of water
goes down through the inside of the door to the weep holes at the bottom.
Some amount of leakage is typical and designed-for in most cars, but the
Kona seems excessively loose in this regard. The weatherstrip rails seem
fully clipped on, their rubber flaps just aren't wide enough. It's kind of
annoying with having to walk around and wipe the drops off the windows
before starting off, when I could clear them from inside in other cars.
_H*
That's kind of my experience. When you get heavier traffic with people cutting in and out in front of you, the car doesn't do as well.
I kind of see these things as the building blocks needed for self-driving cars. Eventually they need to be rock-solid - clearly we aren't there yet.
You know how most car-door windows will sort of self-squeegee any water off the outer surface when rolled down, because the outer weatherstrip rides against the glass as it goes past?
HeheheRecirc turns off after a certain amount of time. 5 minutes or so. My old car, a Toyota Corolla, did the same thing. I think it's supposed to prevent the windows from fogging up since humidity will go up if you don't add fresh air.
