Texas Niro EV
I'm trading in my Nissan Leaf for a Niro EV. One thing I found really useful on the Leaf was LeafSpy. Does anybody know if there is anything like LeafSpy available for the Niro EV yet?
OBD2 reader and appropriate app (Torque Pro, etc.) is all you need.
You can download the Niro/Kona PIDs here.
What do these apps do?
Domenick’s comment is accurate but doesn’t really explain what good LeafSpy is. Let me tell you a few things I used the app for. The feature that was probably the most useful was that it told me exactly what the capacity of the battery was at any given time.
I found this ability to read actual capacity extremely useful on long trips. LeafSpy also has a calculator built in that uses capacity to calculate range based on a user input Watts/mile. I used this feature to tell what Watts/mile I had to achieve to make it to my next charging stop.
The Guess-O-Meter on the 2018 Leaf was extremely unreliable. Using LeafSpy I was able to calculate my range much more accurately. The GOM in Niro EV so far appears vastly more accurate than the Leaf GOM.
LeafSpy has several graphing functions. The graph I reviewed the most was the fast charging graph. This graph superimposed charging speed, battery capacity and battery temperature.
This graph gave me a very accurate picture of how fast charging was increasing battery temperature. The 2018 Leaf has a real bad problem where fast charging caused the battery to overheat resulting in much slower charge rates on subsequent fast charges. This slow charging caused by battery overheating on the 2018 Leaf frustrated me on longer trips many times and is one of the main reasons I abandoned the Leaf and picked up the Niro EV.
Thank you for the additional info. I'm a bit new to Torque Pro, as mentioned above. I was able to figure out how to download and install the original custom PID's, but now that they're installed, is there a preferred method to uninstalling them and replacing them with these newer PID's?
Can you recommend a specific ODB2 dongle and app? Where is the ODB port?OBD2 reader and appropriate app (Torque Pro, etc.) is all you need.
Can ABRP sync with this device? Just curious; I know you use ABRP from your previous posts...I use Torque and OBDLinx MX+ with my Niro EV. The OBD port is to the left of the steering wheel about midway down the lower dash. I am attaching a picture in which you can see it in the top left corner (though I wasn't focusing on the OBD but rather my floor mats) and here is a link to the OBD Device that I purchased on Amazon. https://www.amazon.com/gp/product/B07JFRFJG6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
No layers, just one all weather mat. I ordered from Tux Mat and so far I am loving them. I have only had them about a week though so no word yet on the long term durability.Thank you! BTW, in the picture you sent, it appears you have 3 layers of aftermarket floor coverings happening there. What's the scoop?
I can run ABRP and Torque on the same time on my phone if that is what you are asking. I do give them information on occasion using the OBD and Torque as a go between (we had the first Niro EV in Ohio (and still have one of the very few here as we have to leave state to buy them) so sharing my real world driving results can help with the dataset).Can ABRP sync with this device? Just curious; I know you use ABRP from your previous posts...
Is there a tutorial for dummies on how to get the PIDs installed on an Android phone?OBD2 reader and appropriate app (Torque Pro, etc.) is all you need.
