TandM
Is there a tutorial for dummies on how to get the PIDs installed on an Android phone?
Some useful steps...
Buy Torque Pro if you haven't already.
Get comfortable moving files around on your phone, there are a few useful (and free) utilities out there for exploring your phone's file system
Take a look at the basic steps here:
https://jejusoul.github.io/OBD-PIDs-for-HKMC-EVs/
https://github.com/JejuSoul/OBD-PIDs-for-HKMC-EVs/tree/master/docs
Also, ABRP offers some really nice and useful instructions as well if you go through their guided setup on the website.
Here are the Cliff Notes from ABetterRoutePlanner.com:
Torque Pro Setup:
OBD Reader Setup
Once you've paired your OBD Reader to your phone launch Torque Pro and pick your OBD Reader from the list.
You'll also need to download the following file(s) from the Git repo to your phone to tell Torque Pro how to communicate with your car:
ABRP_Kona&Niro_PIDs.csv
002_Kona&Niro_EV_HVAC.csv
003_Kona&Niro_EV_BMS.csv
Use a file manager to transfer the download(s) from /Downloads to /.torque/extendedpids
If a folder named /.torque/extendedpids doesn't exist, either create it or do the next step then move the files.
Torque PID Import
Open Torque and Import the files you downloaded.
1. Navigate to ? > Settings > Manage Extra PIDs / Sensors
2. If there are already PIDs on this page, select ? and pick “Clear List”
3. Select ? and pick “Add Predefined Set”
4. Pick the file(s) you moved.
Picking What to Log - what is needed for ABRP to work
Configure what data to save in Torque
1. Navigate to ? > Settings > Data Logging & Upload > Select what to log > ? > Select what to log
2. Pick the following items to log (at a minimum, extra PIDs will not be used by ABRP)
!_ABRP_Battery Current
!_ABRP_Battery DC Voltage
!_ABRP_Battery Power
!_ABRP_Fast_Charging
!_ABRP_State of Charge BMS
!_ABRP_State of Charge Display
!_ABRP_Max Deterioration
001_Outdoor Temperature
GPS Altitude
GPS Latitude
GPS Longitude
Speed (GPS)
Logging Settings - necessary to upload live data to ABRP, doesn't do much good otherwise. Uses your phone's internet data!
Navigate to ? > Settings > Data Logging & Upload and configure the "Realtime web upload" settings to match:
Set Web Logging Interval to 5-30s (depending on how fast your OBD Reader can read)
Set Webserver URL to http://abetterrouteplanner.com:4441/niro64
Set User Email Address to your special ABRP Planner Account Email address
Selecting Test Settings will not work, as the account is effectively invalid for the purpose of the test, but you can see "Live Data" on ABRP if you log in to your account at the same time.
Hope it helps.
