How to Promote the Hydrogen Economy Hoax
Electric motors are very efficient - 92-94% is pretty typical. Gears are also quite efficient - about 98%, I think? Similarly, control electronics are very low loss.
If you are truly worried about efficiency, then how can you support hydrogen as a energy storage medium? Hydrogen returns less and 20% of the energy - over an 80% loss.
Your figures are actually ludicrously over-optimistic. It's not worth going through the detail though because even if they were 100% efficient the idea of digging a shaft half a kilometre deep and keeping it dry in order to store only a sunny afternoon's output from one solar roof like yours is laughable. It's probably better to use a powerwall!
One worries about efficiency when it makes sense to do so. Sometimes it is important - like when you are trying to run your car from a battery which is severely restricted in capacity and takes ages to recharge. You have to make use of every Joule to get a reasonable range.
An ICE car is highly inefficient, but this worries nobody because you can afford to carry vastly more energy than is needed. You can afford to chuck more than half away in waste heat and it will still take you 500 miles or more. And recharging takes a couple of minutes, so is not going to stop you for long. Were petrol (gasoline) to suddenly cost $300 a litre, then efficiency WOULD become important in the interest of saving money.
If someone can pay - say - $10,000 and never pay for fuel ever again he is not likely to worry too much about the efficiency of the system, is he.
In my case I support hydrogen because it involves less hassle than batteries. I do not want to have to fiddle about with wires and plugs and look for charging points etc. You are evidently happy with this which is fine, but I want to spend a few minutes every ten days or so which suits me better. Convenience trumps efficiency for me.
You are definitely a troll. The numbers I mentioned are widely known, and checkable.
Hydrogen fuel cell vehicles are dead on arrival.
FCEV are electric cars - they have electric motors, and batteries. The only difference is how they store energy. BEV's have a larger battery, and FCEV's have a small battery and hydrogen storage and a fuel cell to generate electricity to charge the battery.
Fuel cells are much lower efficiency (about 50%, I think) and they require a lot of cooling, because they do not tolerate higher temperatures. This adds aerodynamic drag - about 10% of the total drag comes from cooling. So, FCEV's use about TWICE AS MUCH ENERGY per mile, compared to battery electric cars.
Fuel cells wear out - they last something like 75,000 miles.
The Mirai has two compressors onboard - they make a fair bit of noise.
Protecting the high pressure hydrogen tanks in a crash, requires very strong structure; and if it fails, then hydrogen is extremely unstable, and probably will explode.
Hydrogen is expensive - it costs about $10-12 per kilogram, which is approximately the energy equivalent of a gallon of gas.
If you are willing to wait up to 200 years for all the filling stations to be built - then hydrogen is for you!
Are you seriously suggesting that a half kilometre deep shaft, a thirty ton weight, and an electric winch which stores a trifling 41kW - with 100% efficient motors and gears and everything else is a practical proposition? You can store the same amount of electrical energy in a battery the size of a small suitcase!
And the Mirai is showing more life than two-thirds of the plug-ins listed each month. I'd say reports of its death have been greatly exaggerated, wouldn't you?
You don't know what you are talking about.
https://www.gravitricity.com/
50-year design life – with no cycle limit or degradation
  • Response time – zero to full power in less than one second
  • Efficiency – between 80 and 90 percent
  • Versatile – can run slowly at low power or fast at high power
  • Simple – easy to construct near networks
  • Cost effective – levelised costs well below lithium batteries
Each unit can be configured to produce between 1 and 20MW peak power, with output duration from 15 minutes to 8 hours.
The total storage of each unit is 5-8MWh - not 41kW (sic)
The system is 80-90% efficient, which is what I said.
The system is scalable - add more units, and get more storage.
My calculations are correct. If each unit stores 5-8 MW they are a LOT bigger than a 30 ton weight! I think someone is bullshitting you!
Why don't we work out how big the weights are and how far they have to fall to store that amount of power?
8MW = 8,000,000 x 3600 = 28,800,000,000 Joules. So we have
m x g x h = 28,800,000,000. Divide both sides by g = 10, and we have
m x h = 2,880,000,000. If m is 1000 tonnes then m= 1,000,000 kg, so the pit depth (h) is 2,880 metres - nearly three kilometres deep.
Let's have a guess as to what a 1,000 tonne concrete block is like.
Concrete has a density of around 2.2 Tonnes a cubic metre, so a 1000 tonne block is going to be over 450 cubic metres. Think of an 8 metre cube, or a cylindrical block 6 metres in diameter and 16 metres long.
So nearly three kilometres is too deep to dig? Lets make it 288 metres. Now you have a 10,000 tonne weight. You could make a cylindrical weight 10 metres across and 58 metres long, but your shaft would have to be a bit wider than 10 metres - lets say 12 metres. And of course you'd have to make the shaft deeper by 58 metres to get the weight moving over the full 288 metres. Sound like a horrifically expensive and difficult civil engineering project to me.
You still have the problem of pumping water out of it, too. Deep mines always need to be pumped to keep them dry and that will take a significant portion of the energy you are storing, and reduce the overall efficiency. I doubt if this is included in the claim of 80-90%. Don't underestimate the need to pump water out. It was the need to do this that resulted in the development of steam power which started the industrial revolution and remember a wel is little more than a deep hole in the ground.
If you think this is a practical proposition then, by all means, invest in it, but I reckon its got SCAM written over it in six foot high neon letters. I suggest you do some simple calculations yourself before you part with a penny.
Personally, I much prefer the pumped heat storage system which could store 8MW in a building small enough not to be noticed in an industrial area. You could even put the two tanks underground without having to dig down more than a few metres. In rocky ground, I guess this could be crushed to provide the gravel where the heat is stored! Not a very big installation at all.
Projected vehicle mix:
Source: http://www.cargroup.org/wp-content/...Are-Buying-vs-The-Investments-Automake....pdf
I have my doubts about the "MHEV".
BTW -- It might help if you could point to one -- just one! -- person who was using a solar-powered home H2 generation/compression/storage/dispensing system to power his fool cell car. But you can't, because it's so ridiculously impractical and expensive.
Now you are obstinate, of course I know of one, actually I know of more than one but this is an example.
Or if you ar connected to the gas grid you can do methane reformation at your home. Or you can make biogas - 2 cows will power your Mirai for a whole year.
We can, of course, point to tens if not hundreds of thousands of people who are using their home solar power systems to charge their BEVs, every week.
Is your BEV parked at home when the sun is shining the strongest so you can charge it for free? Can you be sure to find an other customer for the solar electricity that should have gone into your car battery in case parked at home but now can't?
The company [Isentropic, Ltd.] developing it went bust, but the idea is sound (although the thermodynamics is hard to follow) Their pilot plant, however, is being completed by the University of Newcastle who will - I imagine - soon be publishing papers on its performance. If it meets its design spec. I imagine they will be rolled out across the country in due course. They are much cheaper than battery farms and last indefinitely with regular maintenance.
Hey, that's wonderful news! Assuming this is true (sadly, your history of posting here makes that rather questionable), then this means there is still hope for that system to be used for large-scale energy storage. I was following Isentropic, Ltd., and was sorry to see them fail.
Much as I'm a fan of battery-electric vehicles, I've never been convinced that large banks of li-ion batteries were the best idea for large-scale stationary storage. I keep hoping for developments in flow batteries, but the pumped heat electricity storage (PHES) concept certainly is interesting, and I'd like to see more R&D of that concept, or at least a thorough and rigorous thermodynamic analysis proving beyond reasonable doubt that it's impractical.
I do agree that the thermodynamics is hard to follow, at least for me... and at the risk of tooting my own horn on that subject, as a member of the now-defunct TheEEstory forum I was praised as being one of the very few who was adept at understanding thermodynamics. The point I'm trying to make here isn't that I deserve a gold start, but rather that that even for someone with a good grasp of thermodynamics, the energy flow inside a PHES system is difficult to understand.
I guess when you say "obstinate" you are complaining about my posts and my arguments being honest and fact-based.
I didn't watch the entire half-hour video you posted, but from the bits I did watch, the guys are talking about two rather different things: (1) home hydrogen generation for stationary energy storage, and (2) a commercial solar-powered H2 FCEV fueling station. The guy specifically calls that a "commercial" station, which absolutely isn't what we were discussing.
This is typical of your bait-and-switch fallacious arguments, Martin. It is, again, an indication that you know you don't have any honest arguments, so you resort to dishonest ones.
The energy involved in raising or lowering weights is easy to calculate...
...which comes out to ... er... 41kWh This is the theoretical maximum amount of energy this enormous and cumbersome lunacy will store. (Its what you get from your solar roof in 4 hours!)
Altho I haven't checked your figures, this sadly does appear to be the same conclusion I came to on my own for a gravity energy storage system. I did a "napkin math" analysis for building storage tanks for pumped hydro storage to power a one-family home.
The figure I came up with was that with a 30' drop from upper tank to lower, you'd need two tanks each about 10x the size of a typical backyard swimming pool to store as much energy as you'd need for a typical night for the single-family dwelling. This is, obviously, not economically practical.
To be fair to Robert Llewellyn -- which you definitely are not, Martin... no surprise there since Mr. Llewellyn is an enthusiastic EV promoter and you're obviously a dedicated EV basher -- to be fair to him, he did say that the amount of energy stored in just one of these installations wasn't that much, and that you'd need hundreds of them dotted across the landscape, to provide storage for solar and wind farms. If your figures are correct, though, Martin, then "hundreds" is off by more than one order of magnitude, and the overall cost would be prohibitive... which, again, is the conclusion I came to some time back.
Of course, using massive weights of stone or whatever would give significantly better energy density than using water, but OTOH maintenance would be considerably lower for pumped hydro energy storage. Pumped hydro needs only a single turbine to pump the water; the "heavy weight suspended by winches and cables in a mine shaft" needs a lot more investment in equipment and maintenance.
The most extreme proposal I've seen for a low-tech "gravicity" energy storage is cutting a massive round rock piston out of the middle of a mountain, and using pumped water to raise and lower that piston. That certainly would store a great deal of energy as compared to the much smaller system Mr. Llewellyn describes, and using hydraulics (water) it would be far cheaper and more efficient per kWh. I question that such a thing could ever be done on a practical level. But maybe I'm just guilty of thinking small!
For some details on the latter idea, see "'Gravity Power' Energy Storage Plans in Germany"
And from a German language website, an illustration which needs no translation:
We can all sit back and theorise, inventing clever ideas. When you dig into the detail, however, it becomes apparent that there are problems which are so expensive to surmount that one realises they are not as good as you first think. Here's one I had many years back. I'm pretty sure I am not the only one to whom it has occurred.
You sink a pipe from the shore into the deepest part of the ocean which is close to Mindanao I think. You pump fresh water down this pipe (it will be hard work because salt water is more dense than fresh water and you will need to supply it at up to about (from memory) about 20 atmospheres. When it is full of fresh water you put a reverse Osmosis filter over the bottom end and disconnect the pump. Fresh water pours out of the top of the pipe at about 5 atmospheres pressure (again from memory) and continues to do so forever. Not only is it desalinated seawater - i.e. fresh water - but it comes out at some pressure so you can extract energy from it! The reason is the differential pressure at the bottom of the fresh water column exceeds what is needed to filter fresh from salt water.
Perpetual motion right? And that's impossible! So where does the energy come from? Originally from the moon and the sun. They cause tides and wind and these together mix the seawater so that the concentration of salt remains substantially constant with depth. Were there to be no currents, you would find the salt concentration at the bottom of the sea to be much greater than that at the top. The pressure needed for reverse osmosis is linearly related to the salt concentration and the system would not work. So it is NOT perpetual motion but takes advantage of the potential energy available in the sea.
In theory this is perfectly sound, and should work. However, There are so many problems associated with engineering it that it simply isn't worth attempting. I submit it, only, as another example of an initially plausible idea that fails the test of practicality and financial viability which you may find amusing. Not to be taken too seriously! Were I a rogue, though, I am pretty sure I could sell it to a technically naive joker like Llewellyn who is too stupid or obsessed to work our where the problems are, let alone solve them!
Found a possibly appropriate use for a hydrogen powered vehicle:
http://www.businessinsider.com/how-...o-systems-that-will-make-vulcan-competitive-4
Vulcan's upper stage will use cryogenic oxygen and hydrogen, which are more resilient to the punishing temperatures of space.
ULA is also evolving its upper-stage system into what it calls ACES: the Advanced Cryogenic Evolved Stage. After deploying a spacecraft, ACES can be left in orbit for months or years and be refueled instead of being discarded as "dead flying hulks in space," Bruno said.
Sure, this will work :rolleyes:.
You sink a pipe from the shore into the deepest part of the ocean which is close to Mindanao I think. You pump fresh water down this pipe... [snippage] ...the differential pressure at the bottom of the fresh water column exceeds what is needed to filter fresh from salt water.
There was a very long and very contentious discussion/argument over this concept back on the (now defunct) TheEEStory forum.
Some claimed that the system would work and would be powered by the temperature differential between top (warm) and bottom (cold). I disagreed, pointing out that the process as described would, in theory, work just as well if the difference in temperature between top and bottom was eliminated.
I don't know if you could actually use such a thing to produce useful power or not, but I do know one thing: Perpetual motion won't work in this universe. You can't outsmart Mother Nature... or the Laws of Thermodynamics!
So, you're saying that in an isolated very tall column of salt water, the salt concentration will rise at the bottom and fall at the top? That the equilibrium state is a gradient with greater salt partial pressure at the bottom? If so, then I think you have solved the conundrum! If that's true, then the system as described might well generate useful power without being perpetual motion. It would be harnessing indirect tidal and solar power, since the sea is stirred up constantly by tides and by day/night temperature differentials.
But as I said... I'd love to see it tried to see what would actually happen!
"In theory, there's no difference between theory and practice. But, in practice, there is." -- Jan L. A. van de Snepscheut
[much snippage]
Hydrogen certainly does have its uses as fuel for the booster stage of large rockets.
And fuel cells are useful in spacecraft, where space is at a premium and the cost of the hydrogen fuel is not an important consideration.
I see your point, though; that the chances that an orbiting spacecraft will be visited by a H2 tanker spacecraft for a refill... are pretty low, given the current state of the art for spacecraft!
Where's that Space Elevator, dammit!
Actually, Neil, you're seriously underestimating the efficiency loss from the mechanical system. The winch mechanism and cables won't be 98% efficient. An EV loses about 20% efficiency from mechanical losses, including tire flexing. I would guess this elevator cable system will be more efficient than that, because it's a simpler system than a car's drivetrain, with fewer places where energy is lost; but it will still be rather less efficient than the electric motor itself. Electric motors have a remarkably high efficiency for a mechanical system which converts energy to useful work; just about any other work-producing mechanical system you can name is less energy-efficient.
Just because Martin is wildly wrong about using hydrogen as a transportation fuel, and almost as wrong with his incessant EV bashing, doesn't mean he's wrong about everything. He is certainly exaggerating the amount of mechanical efficiency loss from the elevator system, but I agree with him on this: The cost/benefit ratio for the "gravicity" system as described would be far too low to justify the cost.
Elevating an extremely large weight on one or more hydraulic lifts might well be an even more energy-efficient method of storing "gravicity" energy, and would not involve digging deep holes. I'm still far from convinced that the cost/benefit ratio would be advantageous, but I'd certainly like to see a pilot project done.
Don't forget they have to use a quantity of oxygen, typically liquified.
Actually I was amused the article claimed to compete with SpaceX by having an orbiting hydrogen-oxygen rocket stage. Some of the other claims in the article were even more amusing.
Source: https://www.makai.com/ocean-thermal-energy-conversion/
Experimental power generation works but the pipes were damaged in an earthquake. The floating unit will reduce one risk but add a storm risk.
Given a choice between "n" hydrogen fueled vehicles and "4n" battery powered cars, guess which one wins. Point of reference, 100 KW would be 400 miles of battery EV every hour versus 100 miles of fuel cell powered miles.
