I'm still having the car run ICE with no heat demands, no seat heater/defroster, and temps in the 50's. It happens when I first leave home, and I usually notice it after my first stop sign or 2. It will then run for a while unless I cycle the key to force it. SOOO frustrating I can't make the car act like an EV sometimes. Haven't bothered to bring it to dealer b/c I assume I'll be sent home with a "we don't see anything unusual"...
Well, the Clarity is not a true EV, it’s a PHEV. Also, there is no way to select “pure” or 100% EV (battery only) driving. It is, however, quite possible to drive it like a virtual EV with almost all (but not quite all) your miles on the battery for the first 50 to 60 miles in the summer, and 30 to 45 miles in the winter. YMMV depending on how far north you live and how aggressive you drive.
For me in KY, with on passengers or luggage, on no more than rolling hills, and obeying they speed limits, I get mid 60s EV range Spring to Fall and mid 40s in winter without the ICE inning on except as noted below. Note that ceramic tint, preconditioning, garaging, and non-extreme climate help a lot to stay EV vs gas, along with moderate driving and local speeds limited to under 60 mph.
So I’ve been able to go 14 months and 9,200 miles on 15 gal of gas since I’ve only taken about 700 miles of out of town trips. I do have the ICE come on very occasionally and for short periods of time. That’s normal and to be expected. The engine has to exercise itself to make sure it’s always willing and ready to instantly come on when you call for it. It’s just keeping everything lubricated and stays on until it reaches operating temperature which gets rid of any condensation in the oil and in the exhaust system. You are just defeating this benefit and not helping your engine by trying to turn off the ICE before it warms up. Also, it doesn’t burn an appreciable amount of gas. I haven’t used HV in 10 months and haven’t even lost a bar in the fuel gauge from the occasional and short System Checks.
Although there are some conditions that will call for the ICE (see p 13 of the manual), it is very easy to achieve virtually the same economic and environmental benefits of a BEV during local driving. As a PHEV, the Clarity the gives you all that plus the added benefit of unlimited range at 40 to 50 mpg in semi-luxury. So I say don’t obsess about the ICE running very occasionally when you are in “EV mode” because it’s normal expected behavior and has no discernible cost.
But there is always a fly in the ointment so to speak. Although not mentioned anywhere by Honda, it is well documented on this forum that the Clarity has one unusual quirk about its ICE. When the battery is fully charged it cannot accept any more charge by regeneration and so to protect the battery, the ICE will start and in some not fully understood way keep the battery from being overcharged. This is most often seen on a down hill after a full charge or with hard braking or 4 chevron regen. Others have posted that drawing down the battery with cabin heat/defrost at start up can help mitigate this, but I’d your hill is very steep it may not be enough. Then some have tried not charging to 100% but that takes some effort. FWIW, mine did this for a while and I’m not on a hill. I found that not calling for 4 chevron regen and braking gently the first 5 miles or so eliminated it for me. Or it could have been just that my car and battery ages a little bit. I just know it’s stopped except for one time I had to panic brake right after a full charge and the ICE came on.
If it’s only happening when you leave home on a full charge, the it’s probably the no regen on full charge to protect the battery by ICE start thing. (Wish we had a name for that!)
Hope this helps and hope you enjoy your Clarity as much as I do.
