HondaLink App Update
  • Thread starter Thread starter vicw
  • Replies Replies 270
  • Views Views 94K
I have Galaxy S8+ running Android version 9. I went into settings/apps/Hondalink and turned on notifications. I now get charge complete notifications. I also see upcoming events from my Google calendar in the Hondalink app. (Don't really see the utility in that.) The odometer reading updates correctly - much better than in the previous version. And the location of my car map feature (which was always wrong) is removed. Find my car, under "remote commands", seems to work.
New version seems to work fine for me, even though it did not add any new functionality.
I am 100 miles from home and they are experiencing widespread power outages there due to the recent storm (400 power poles down; will take a while to fix). I had the idea to use the HondaLink app to find out if there is power at my home. It says "plugged in" which is a good sign but not sure how to interpret the range information. I've had no issues previous to this with it reporting accurate range information.
What was the latest update time on your app? And where does the "11:34" time come from? Is that in your app or phone?
I have Galaxy Note8 running Android version 9. I no longer see any charging info or remote CC. Screen shot attached. I've tried re installing the app but same issue persists. In my notification panel I have a "connecting to vehicle" pop up which stays on all the time. Any suggestions?
There should be a dismiss button. As you, connecting vehicle just spins and spins and doesn't do anything.
Happens to me all the time. Do a find my car through the app and the battery should refresh after a few minutes.
I had an incident today at work. I was plugged in, but they cut power to the outlet where I was plugged in, as they were working on an electrical panel.
My car still showed plugged in, but not charging. When I tried to start charging, I got an error. It wasn't until I actually got to my car that I discovered that the outlet was dead.
I moved to a new place in the parking garage, and plugged in to a working outlet, then all was good.
It is a possibility that the power is out with the weather issues?
To update this,
There is power, looks like there has been power.
I tried "Find my car". At first it said it couldn't find it. Then after a few minutes it said "Location updated". But the display of range still says zero and fully charged. I will drive the car and see if that fixes things. I've had no issues with the app until now. This is the current version of the Apple app.
To update this,
Mine did this a few days ago, but Find My Car also stopped working ... always said the car car couldn’t be located, though it was sitting it my garage as usual. I deleted the app (iPhone) and reinstalled and everything started working again.
Thanks. I was wondering how many segments it has. As in how fine a detail it gives you.
When i open honda link a few days ago a window popped up and said updated required to continue to use this app. The small soc bar has no segments but acts more like a thermometer and slowly fill the bar as the soc increases. It does show the percent of charge at the top. I liked the look of the old app better.
Thanks. I wanted to know to help me decide whether to get the update, but I accidentally did an update all and got it and then had to get the newest mandatory update.
I like the thermometer style with more detail than the segments and the newest update returned the % SOC (yay!) but I lost the odometer update.
Well, after 2 weeks of complaining here and gnashing of teeth at home, it’s started updating the odometer regularly. Don’t know why or what did it, but I did try all the suggestions posted here.
So I’m back to happy camper status again.
Have you tried “Find My Car” followed by “Update Location”? The seems to sometimes work.
Yep, I tried that but thanks for the suggestion. I have not worried too much about the mileage being accurate because it isn’t information I need when away from the car. I just like when things work the way they’re designed.
I'm pretty sure it's a combination of the way you're holding your nose and the relative humidity.
Don’t forget the Coriolis effect and the possibility of drunken Honda engineers at Karaoke night thinking how funny it would be to add a random number generator to some of the algorithms.
To update this,
Last update. I drove the car and everything in the HondaLink app seems to be back to normal. Go figure.
ANYBODY! - Hondalink is now in miles only - but car is correctly in kilometers. called support and they told me to 'connect to the car'.
Did all that; deleted app; rebooted car, rebooted phone, re-downloaded app, restarted car, hondalink (car) connected, hondalink (app) connected, logged-n;
and voila MILES !! :-( :-( .. does anyone know how to get the app to be in kilometers ? Thanks
On an iPhone, Honda Link displays the distance and temperature in the same units as the phone is set to. It doesn’t get that info from the car.
So go to Settings, General, Language and Region. Then select Canada and you will get HL in kilometers and Centigrade.
Sorry, but I don’t know how to do this on an Android phone.
PS: I refuse to trust any system of measurement that’s so easy even a 3rd grader can do it.
Let’s see, 2 ft 3 15/16 inches minus 1 ft 5 3/4 inches is ..., wait, wait, I’ve almost got it... there’s how many feet in a mile and ...
Well, at least when my doctor weighs me in kilograms, I feel lighter since it’s a smaller and less embarrassing number.
