I'm a new owner. Loving the car for the couple days I've had it. My wife drives a Leaf so we aren't completely new to EVs, but I drive a lot for my job so I wanted a gas tank as well... and when the Volt was too small and the Niro not quite right (and a shorter range than I wanted), I discovered the Clarity. Which seems perfect. I have a few questions about maximizing range.
As I understand it, anytime I'm doing city driving I should stick to using electrical when possible, but switch it to HV mode when I'm on highways (is this correct) to maximize range/mpg.
In a scenario where the battery is down to a range of 5-10 miles, should I put it in HV Charge Mode to charge it if I'm still doing city driving? Should I avoid the charge on Highways or is it actually better there?
When I know I will be going home with more than enough time to fully charge the car, if the battery is tapped out, should I put it in HV Charge or just wait till I'm plugged in at home. Basically, when having either option which is the better charging method.
Hopefully these questions make sense.
