I think I saw a symptom of the engine braking system with an OBDII recorder system. The mass airflow meter went to a very low reading when the motor RPM's were still around 1500. There had been a period of regeneration. I was in HV mode, and the battery was reaching the top of the 'target' charge, SOC was around 50%. Engine braking lasted about 30 seconds once, then 20 seconds a second time. I don't have a record of fuel flow, or spark, during this time. The first time, I was driving 73 mph and slowed to take an exit: The ICE was powering the car in HV mode, and battery SOC started to go up with regen for the exit. The second time, I was driving 60 mph +-, and came into a small town, and regen was driving up the SOC. Both times, the engine did not shut off, but just 'lost' air flow in a step drop. At other times the air flow is relatively proportional to engine speed.
I drive most of my miles in HV mode (I drive lots of 100+ mile trips.), so I haven't noticed the EV mode engine braking.
I just started recording mass airflow, to see if this would show engine braking... Seems like it does.
ClarityBill,
I'm totally fascinated by the original theme of this thread, which refers to the Clarity in EV Drive mode starting the ICE in response to regen braking (paddle or pedal)
when the battery is fully charged. Are you finding other times when the ICE starts up in response to regen braking when the battery is
not fully charged?
In HV Mode, the Clarity selects from EV (EV Drive mode), ICE (Hybrid Drive mode), ICE+EV+clutch (Engine Drive mode) and regen braking as it sees fit. I don't believe it ever starts the ICE to dissipate power unless the battery is fully charged.
1. You saw what you believe is a symptom of "engine braking." Are you referring to the ICE driving the starter motor/generator in such a way as to use up the power coming from the traction motor operating as a generator to slow the car?
2. When you say "motor RPM's were still around 1500" are you speaking of the traction motor, the starter motor/generator, or the ICE?
3. "There had been a period of regeneration." Does that mean regen braking had been taking place? Was it due to a downhill section? I assume HV CHARGE Mode didn't spontaneously take over. Did regen braking then stop because the battery became fully charged or because the bottom of the hill was reached?
4. "I was in HV mode, and the battery was reaching the top of the 'target' charge, SOC was around 50%" Is the top of the target charge the 57.7% charge maximum for HV CHARGE Mode or was 50% the SOC level that was displayed when you pressed the HV button?
5. "Engine braking lasted about 30 seconds once, then 20 seconds a second time." Are you interpreting low mass-airflow as evidence of "engine braking?"
If the ICE starts up unexpectedly in response to regen braking after leaving their garage with a fully charged battery, it doesn't seem that there would be low mass-airflow because the engine is making sparks, sucking in air, and generating power. However, I wouldn't be surprised by anything happening in HV Mode unless that thing happening uses up more fuel (as ICE counter-intuitively does when it starts up in response to regen braking with a fully charged battery).
I really wish Honda would explain the difference between the operation of their non-plug-in hybrids and the operation of the Clarity when regen braking occurs while driving in EV Drive mode with a fully charged battery!
