Ok, hang on - those that read my other posts know I can get lonnggg wind---edd.
There is a lot already said here, first and foremost is that a Parallel PHEV is not an EV, and cannot be compared to one, completely different power trains, energy management and well, if you want the behavior of an EV, buy an EV. If you want the synergy of a Series PHEV, then buy that (BMW with Range Extender) as that is not what the Clarity is. It's a parallel electric/ICE-Generator drive train, and actually a really good one. You can even buy turbine powered hybrids (series and parallel, so the heck with an ICE) just google Capstone Microturbine cars. A full EV has no ICE to turn, so when the battery is full, no regen occurs, and the "braking" is, well - using BRAKES, it has no parallel transmission architecture to deal with, just a CVT (or none if it's a golf cart).
Simply disabling the ICE would completely change the behavior of the car and the driver experience. I absolutely guarantee that if the regen system could have been made more fuel efficient given other design concerns, Honda would have done it as in this market - gains are small and eMPG is a big marketing concern.
Completely disabling the ICE may be something that a few people would want to do, but auto manufacturers don't build for a few, they want to sell a lot.... so they make what ALL hardware manufacturers do (software lends itself to more customization) they make compromises based on market research. Heck, that's why I got a crappy sound system in the factory touring class Clarity (but I bet others here think the stereo is just fine, just like I am not bothered by the regen/ICE design). Hey, I'm even getting rid of those annoying low rolling friction tires for some better handling ones, don't care about the electric range penalty, have a gas engine generator if it goes dead. Honda likely believed there would be more people interested in every joule of electric motive efficiency so saved a few pounds in speaker weight and wanted the margin in COGs/BOM (I mean, that has to be it, right
?). Fortunately I could easily fix the stereo issue, and knew that when I bought the car. Changing the powertrain design and programming is likely more difficult. I think the biggest problem with the Clarity is the lack of technical information. You can youtube a full teardown to loose "bolts" of the Chevy Volt or even a Tesla (Rich Rebuilds), but digging for info on this vehicle is still difficult for a number of reasons (it's new is one).
However, if you want to spend some money you can read all the technical info publicly available regarding the e-transmission and power train here:
https://www.sae.org/publications/technical-papers/content/2018-01-0415/
Let us know what you find out. Considering that the goal of Honda was to make a PHEV that was user indistinguishable from any other high end Honda sedan in driver experience with the exception of far less use of fuel and a reasonable choice in motive energy (for short, non highway commutes) of electricity over fuel, I think they did a good job. If you bought the Clarity PHEV wanting to never use the ICE or have it turn on, you bought the wrong car - get the Clarity Electric, a Bolt, a Tesla, etc.... However, I am not convinced that you bought the wrong car knowingly - Honda did a poor job of defining the Clarity variations from a marketing standpoint and I think they blurred the lines a bit in consumer expectations. The info is there, but as MUCH evidenced in this particular forum/thread - you really have to dig to find it.
To put this issue to rest we need only one simple data point > drag ICE fuel burn (as that is the only concern really presented here). So, charged car, top of mountain, moderate temperatures, fuel flow meter (or electric sensor attached to all fuel injectors to read the impulse), and EGT probe (or a good ODB probe). The trick is that when the ice is triggered Honda chose to go ahead and warm up/test the motor. What you need to know is after that, does the regen energy burning and turning the ICE, actually consume gas. If not, then the ICE "warm up" fuel is inconsequential for normal drives as it happens only once and at idle for a short time. So, we warm up the engine, don't turn the car off, and then start down hill regen braking to our heart's content.... then read data. Who is up for that? I admit I am not...
I very often turn on HV mode to trigger the ICE and let it warm up while cruising the route from work on the surface roads. This lets it warm up gently (like a regular car) before I reach the toll road to head home... and well, let's just say I use all available acceleration energy available in the Clarity and prefer to not high rev a cold engine. 100mph electric limit my azz!
Cheers,
Cash
