MNSteve
Sorry, I have to disagree. This is not a driver error, but an error in the way that the car controller is programmed. If a particular combination of modes results in a safety issue, that combination of modes should not be possible for the driver to select. Not having enough power to drive the vehicle normally is a safety issue and should not be happening, no matter what buttons the driver has pushed.You were using HV charge in a way that’s not recommended. The owners manual indicates that HV charge is best used at highway speeds, and from use, HV Charge is not recommended for any significant uphill. Your outcome is not surprising, and is user error, not a defect with the car.
In this case the controller should have detected the need for the power produced by the ICE to be used to propel the car and disengaged any attempt at charging the battery.
