This is no doubt a silly question to some, sorry:
The low tire pressure light came on, so after about 10 miles and 15 minutes of driving, I pulled into the nearby gas station. The tires say Max Pressure 44 psi but the door frame sticker says Cold Tire Pressure 36 psi. I couldn't decide which number to pump them up to so they are still low. How hot will the tires be after 10 minutes of driving back to the station? Do I assume they're still cold and fill to 36 psi, or do I assume they are hot at that point and fill to 44 psi, or do I assume they will be warm and just split the difference and fill to somewhere in between? The gas station air pump is one of those where you set the pressure to a certain number and it stops once it gets there but I don't know what number to pick.
Thanks for any advice.
