after a 500 mile HV trip at 49 mpg
Nobody is reporting any EV range estimate problems that I know of. Your erroneously high EV is probably due to that long downhill on your last trip which the algorithm used to calculate what it expects your next trip to be like. I wouldn’t worry unless after a “normal” trip, it doesn’t come back down to a believable range.Does this also fix the problem with the EV being too high. I just returned from a trip in the mountains where I ran mostly in HV. On my return, I switched HV off and did the last 25 mile which was mostly downhill and gained about 15 miles of EV. After I charged the car that night, the EV miles showed 82.5 which I know is wrong.
Just picked up my Clarity last week here in Canada. My HV range shows the equivalent of 351 miles (565km). So not sure if mine was fixed at factory as I have noticed some other people in Canada trying to get the software update.
Ken, I wasn't even worried about the HV range problem but I just got it fixed. I was just reporting that there is still a problem with the EV range estimate when you spend some time driving in HV mode and especially if there is a long downhill part of your trip.Nobody is reporting any EV range estimate problems that I know of. Your erroneously high EV is probably due to that long downhill on your last trip which the algorithm used to calculate what it expects your next trip to be like. I wouldn’t worry unless after a “normal” trip, it doesn’t come back down to a believable range.
Understood, bpratt.Ken, I wasn't even worried about the HV range problem but I just got it fixed. I was just reporting that there is still a problem with the EV range estimate when you spend some time driving in HV mode and especially if there is a long downhill part of your trip.
The erroneouly high HV range estimate shows up more and more whenever you put gas in. The only way it will go down without having the update installed is to drive exclusively in HV with no EV for several trips but it will go back up as soon as you drive in EV for a while. The update is the only permanent fix for it.How is your range going as you driving the car more? I picked mine up today with full tank of gas and full charge, and it showed a range of 691 km (431 miles) which doesn't seem right but isn't as crazy as those getting 1000+ mile ranges on their display.
After topping up my tank (added 9 litres) last week for the first time in a month (drove 2150 kms virtually all electric!) my gas range jumped to 1901 km!! Clearly my car does not have the range fix applied to it yet ... I will try to get that when I take the car in for its first servicing in a couple of months - note that a while back someone posted that the bulletin for this fix in Canada is number J-20-18.How is your range going as you driving the car more? I picked mine up today with full tank of gas and full charge, and it showed a range of 691 km (431 miles) which doesn't seem right but isn't as crazy as those getting 1000+ mile ranges on their display.
