I was enthusiastic about buying a new 2025 Kona Limited EV recently. My first 100% charges at home were indeed right up to that 261mi estimated. It dropped during the first 2 weeks to the 240's. It was perhaps about 45 degrees Fahrenheit in garage. I charged up to 100% prior to a micro trip I wanted to go on which was about 100 miles each way. On the way stopped at Electrify American 350kwh station just to top up as I'd not used one before. I admit I did NOT pre condition the battery on a 40 degree day. I'd basically driven about 55 miles at that point and was already at 72% charge. I was only able to pull 32kwh so only stayed there about a half hour getting it to 81%. I left and continued onto the remainder of the one way part of the trip which was about 50 miles. On the way home it was burning electrons like crazy. I got home at 1%. at 20% on the highway it alerted me to stop and charge. At 10% it warned me once again about taking a break and charging.
I was pleasantly surprised at no point did it slow my speed by default as some cars will do. But I figured it was damn the torpedoes as I had NO Place along the way to charge. Drove up and plugged in my Level 2 charger and was ok. But honestly the estimated 261miles for this car is greatly inflated, which greatly disappoints me. I was coming from a 2021 ID-4 RWD which was rated at 240mi and while it was no long ranger tended to sip it's electrons a bit better.
I have a trip in My coming up I'd strongly considered taking this car on which is about 275mi each way. Plenty of charging places along the way on I-15 but according to A Better Route Planner would spend about 2 hours of charging which is just absurd to me. I thought for sure it could be made with at the most 2 charges and about an hour total. But after this little run this week don't doubt it may be a long road to hoe. I'm hoping it has more to do with the temperature than anything else and that perhaps in May with warmer temps I'll get a lot closer to the estimated mileage. But at 80mph it's not likely. Any thoughts? Sure makes that Ioniq 6 long range look good.
