Anyone keeping track of the battery's soh
I've been taking a reading every month. This month's was not looking great
SOC 89.9 - 11.5. I'm guessing this represents the top & bottom buffers. The 11.5 stays pretty consistent, but the 89.9 is the lowest it has been. SOH & capacity just keep dropping, but if you take into account that the buffer keeps growing, the overall capacity seems to stay the same at about 113 to 114Ah.
I've only done DC charging once & tend to keep the charge in the 50-80% range most of the time. I allow it to go to 100% and sit for a couple hours once or twice a month to rebalance. 1.5 years on the road & 9k mi. I'll be interested to see what Mini has to say when I bring it in in June for 2yr maintenance.
I did do a 98mi drive yesterday & had 24% left over, so that is still well over the 114mi range rating
I’ve found that my SoH seems to drop during periods where I don’t leave the car plugged in and recovers afterwards, but it takes multiple days of being plugged in. If SoH is based on charge balance, I’m guessing your battery is out of balance enough that leaving it plugged in for a couple hours doesn’t do much.
Do you mean the mismatch between the nominal capacity and the capacity we’re seeing in electrified/mi3? I agree, it’s strange. I have 2 theories:
Yep. If I can pick one, I'll take option 2.
BTW, carscanner gives me the some data too... With a mini Cooper se profile...
If anyone ends up getting a definitive answer, please let us know.
I guess I'll give that a try. I figured since the cell voltage range is only 0.01V, it was probably pretty well balanced, but maybe SOH has nothing to do with voltage range
My latest check. 30,174 miles. 26 months old. I have charged it since mid July. Going to give it a few days on charge.
Darrell, I was trying to keep max charge to 80-90, but also suffered capacity loss. After switching to full charges before I used the car, I regained some.
wow that is way beyond my latest reading. I'm only at 13.5k at 27 months. I haven't seen numbers like that since the 4th month. My numbers have stayed the same for about the last year. Going up to 100% a couple times a month helps. Generally keep it between 50 and 80%. I guess I could charge to full a bit more, but I really don't drive that far, so it would be sitting at nearly full charge a lot. Got home from a trip the other day at 1%, close call
After seeing my SOH take a dive, I switched to 100% charges. But I do them so it hits 100% a few hours before I know that I'm going to drive somewhere. I try to avoid leaving it at 100% for more than a few days. I need to check, but I have a feeling that I have a higher SOH than a year ago. It did take quite a few cycles to climb back up. Anyone who is borderline for a battery replacement at 8 years should avoid charging to 100%! You haven't run it low until you've driven 2 miles at -- I was down to about 3 bars by then.
These screens are what you get with the free eFlow version, mini not plugged into charger. This is a 14,000 mile 3+ year old 2022 mini that is driven about 80 miles twice a week and charged overnight to 100%. On other days it may be driven a few miles around town but not charged until the day before these trips. You have to upgrade to see the EDME error as well as anything else. I don't see any errors reported by the Mini, dunno what the EDME error is. I'll have to look into it. Perhaps a way to get some money out of me :).
Just checked mine again. It had a 100% charge after the last check, and sat for a day on charge. Today, I ran it down to 51%, then fully charged again as I need a full battery for tomorrow. It's been floating a couple of hours. I've gained another 0.2Ah, now 95.8. Mileage now 30241.
I fully charged my battery last night. With the car still plugged in, the charge light is not on. Is this new behaviour?
9 months old, 12 000 km. and SOH 100% (Capacity 96.89 Ah). I always charge it to 100 using 16A, 220v. Once per month i do 6A slow charging.
21,371 miles, 4 years old, 96% SOH:
Most charging is at home on Level 2. Not much driving the first year+ of ownership due to COVID restrictions, but I have taken several road trips the past 2 years with plenty of DCFC to get there and back (9 different states so far). A couple months ago, SOH dipped to 95% but some float charges brought it back up 1 point.
I'll revive an old thread, since I am new to the game, and there a a number of
people here much smarter than me:). I am limited to home charging via L1 with the
flex charger. Did we determine to limit charging at 80% as the book says,
or is it acceptable to go to 100% each time? I have a '23 with 14,000 miles.
I'm getting the impression, correct me if I'm wrong, that it is really difficult
to determine the SOH of these batteries.
True of all EV batteries, at least as I understand it.
Anyway, the only possible benefit that I can see to babying the battery is in the hope that if you sell the car down the road, it will make it easier and/or the vehicle will be worth more to an astute buyer. But, there is no guarantee of that, or for that matter, that babying will truly make a significant difference in the long run.
Thus, I would say (and I do) charge as need be, and not lose any sleep over it.
I am on very good terms with my dealership (since they first opened). Both the chief mechanic and the manager have repeatedly told me that ABC and charging to 100% are good practices.
I charge to 100% on L2, but have scheduled departure so it hits 100% just before I leave. Every so often, I leave it on charge for a day or so to equalise cells. Hitting 100% for scheduled departure is going to be trickier on L1.
