Tire Repair Kit
  • Thread starter Thread starter zbartrout
  • Replies Replies 33
  • Views Views 11K
I ordered the official honda replacement part from https://www.hondapartsnow.com/
ordered it 2/15, arrived today, shipped from NH to MA.
here is the link https://www.hondapartsnow.com/page_product/searchbyname?vin=&make=Honda&model=Clarity Plug-In Hybrid&year=2018&submodel=&extra1=4 Door TRNG (CLARITY PHEV)&extra2=KA CVT&filter=()&keywords=tire repair kit
it was $65.60 + $12.84 shipping/handling.
it is an exact replacement for the honda part. expiration date 2029.
I was easy to replace the original bottle of the sealant with the new one: took a few minutes, no special tools. same size as the old part.
Thanks! I ordered instantly after reading your post. I wasn't interested in anything but an exact-fit replacement, so I really appreciate you doing the hard work for me, @Johnhaydev. I paid 18 cents less for shipping from California to Michigan instead of Massachusetts. For some reason, they didn't charge sales tax, but I bet they do for California customers.
Thanks for this information! I just placed my order, and it’s coming next week. I guess they stocked up for all the 2018 replacement orders. I added a tire plug kit a few weeks ago after reading all the comments about these patch kits and how relatively unreliable they are. Luckily after 50k miles I haven’t needed to find out for myself. Next up are replacement tires because the OEMs are wearing out.
Got my Slime refill. I have good news and bad news to report.
Bad news:
The Slime bottle is skinnier and longer then the OEM bottle. That means it wont fit the OEM pump.
Good news:
made by the same company, same milky liquid, same cap/valve( except color),hose. The cap can be unscrewed. So i unscrew the new and old. Pour out the old liquid from the OEM bottle and fill it with the new liquid. I also replaced the cap/valve/hose with the new one.
Slime refill cost about $25. OEM $63+shipping.
Bad news:
Good news:
The OEM slime kit I ordered arrived today (perhaps the last one HondaPartsNow could get?). I paid $65.60 + $12.66 s&h, but the big bucks replacement came with this neat new Honda pictogram sticker set:
I was happy the bottle is so easy to replace. The cover slides off easily after removing the power cord from its cavity. Then, after threading the hose out through the hole in the case, you just tilt the bottle all the way up to disengage the connection locking tab and pull the bottle away from the compressor connection on the right.
Does anyone want my 6-year old, never-used OEM bottle of slime? I'll toss it next week unless someone PMs me first.
Whats the expiration date on it? I hope it is not an old one.
The "old" one I'm willing to donate from my November, 2017, Clarity is the one on the left in my photo with the "EXP 02/2024" sticker on it. So it officially expired last month, but I don't know it the carriage turned into a pumpkin on the 29th. Interestingly, I didn't see an expiration sticker on the replacement bottle, so I made one up that says "EXP 03/2030."
MY2018 bought in Dec 2017. I believe the repair kit would still work if only I could get the fitting to thread onto the valve stem. I believe I probably didn't follow the instructions closely enough and should not have turned on the compressor before having the fitting fully threaded on.
If the valve stem were longer such that I could grip it gently with pliers while turning the hose fitting on, I believe I could likely get it threaded far enough on to engage. But threading with fingers far enough was impossible once under pressure.
This past weekend, I had a piece of metal puncture a tire and when I attempted to screw the plastic/metal shrader fitting of the repair kit hose onto the valve stem, I could not get it to thread far enough on to engage and allow air / gunk to flow. I am sure the gunk would have worked because later I noticed a bit of it leaking from around the hose end.
So, for those who have used this system successfully:
1) What do you do to clear out the gunk and use the compressor just to supply air again? Hold it over a garbage can, trigger the valve and hope for the best? Compressor is still under 60psi of pressure.
2) Is the gunk a one and done supply or can it be used subsequent times (particularly if the first time no flow happened)?
3) Under pressure, the device knob will also not switch from gunk flow to air flow setting.
FYI, I also had a time getting the wheel off due to rust of the hub. Against the aluminum wheel. I sanded away rust and applied a bit of grease.
I've never used my Clarity's tire repair kit (although I just changed the tank of slime and will send my unused, just-expired-but-refillable tank to anyone who asks for it before April, 2024). However, the Owners Manual answers one of your questions.
It says not to use the tire repair kit in these situations:
• The tire sealant has expired.
• More than one tire is punctured.
• The puncture or cut is larger than 3/16 inch (4 mm).
• The tire side wall is damaged or the puncture is outside the contact area.
• Damage has been caused by driving with the tire extremely under inflated.
• The tire bead is no longer seated.
• The rim is damaged.
For your question 2), bullet 2 indicates the slime tank is a single-use proposition.
I didn't know your item 3), that the Air/Repair knob can't be turned to the Air setting when the hose is still connected to the valve after using the Repair setting. Did it make a mess when you unscrewed it? If so, that's what Honda decided had to be the case. I'll be putting some rags in the compartment with my tire repair kit to wipe up excess slime.
So if you can't turn the Air/Repair knob when the kit is under pressure, you have no choice but to perform your procedure 1): unscrew the hose from the valve, switch to Air, and blow out any slime remaining in the hose. Then you can switch to Air, reconnect the hose to the valve, and pump more air into the tire, if necessary.
I hope I never have to use my tire repair kit. Your experience was worse than I expected it would be. Please accept my condolences.
