AndysComputer
As we know, Mini don’t allow us to set a max charge level cutoff, it keeps going until it hits 100%. For cars that get used daily I don’t think it much matters, and I imagine BMW added enough top buffer that it isn’t really 100% anyway but…
As our Mini isn’t used daily and I wanted to keep things as simple as I can for my wife I have been doing the following to limit the car to 90% without having to monitor it and unplug.
Our EVSE is a smart one which provides a couple of features that mean we can pull off a charge limit due to our usage profile.
Essentially I tell my wife to only plug in when she gets home if the car is below 50% charge. This takes a few trips for her.
I have a 15kWh session limit set on the EVSE. So it cuts off after 15kWh is delivered which adds about 50% and thus takes the car up to about 90% allowing for charging losses at which point it switches off.
She typically plugs in at just under 50%, so it works well.
The EVSE also offers a session time limit so a quick bit of math on charge rate and time would achieve the same thing.
If we used the car a lot such that we got home on say 20% (this is a once every few months type thing) it would only charge up to 60% before cutting off. That’s fine as over the next day or two she’s use it and it would drop below 50 causing her to plug it in again and it would hit 90.
This technique might work for a few ppl on here who are light users and would like to avoid keeping the car at 100%. Just adjust the session limit to whatever you’re comfortable with for your use case. Assuming your EVSE has such a feature obviously…
