This is a little long since I’m posting for those with no electrical knowledge.
According to the manual and the label, the Clarity EVSE requires a dedicated 15 amp circuit and draws a maximum of 12 Amps.
Here is what you need to know.
Most 15 Amp residential house circuits are wired with 14 gauge wire (12 g for 20 amp) and generally speaking you size the circuit for 80% of the circuit breaker’s size. So here, 80% of 15 is 12 Amps which is the maximum draw of the 120v EVSE or “charger” included with the Clarity. So far so good; just plug into any properly wired 15 or 20 amp outlet in your garage.
But you wish to use an extension cord (manual says no, but it also says things like have an electrician inspect the outlet which nobody does) so here is how I “flaunted” the manual:
First choose an appropriate extension cord for your particular use.
1 Use correct size. For 12 Amps ( lets be safe and size for 15 Amps) and lengths up to 50 ft, the following table tells you that a 12 gauge cord will be plenty and you don't need to waste your money on a bigger 10 g cord as posted above. (For under 25 ft, even a 14 g would be OK, but I only buy 12 g)
Cord Length Device Amperage Rating Good for Use with Minimum Wire Gauge
- Christmas lights
- Work lights
- Portable fans
- Hedge trimmers
- Lawn mowers
- Power drills
- Table saws
- Chain saws
- Circular saws
- Shop vacs
- Air Compressors
- 12 Gauge
(Heavy Duty)
or 10 Gauge
(Extra Heavy Duty)
- Christmas lights
- Work lights
- Portable fans
- Hedge trimmers
- Lawn mowers
- Power drills
- Table saws
- Chain saws
- Circular saws
- Shop vacs
- 12 Gauge
(Heavy Duty)
or 10 Gauge
(Extra Heavy Duty)
- Christmas lights
- Work lights
- Portable fans
- Hedge trimmers
- Lawn mowers
- Power drills
- Table saws
- Chain saws
- Circular saws
- Shop vacs
2 Use correct type. I use an SJW type. This means it’s flexible (S), suitable for outdoors(J), and more heavily insulated (W) so it holds up better to use on rough concrete. This designation will be stamped on the cord.
3 Use correctly and safely. Water and electricity don’t mix, so you have to keep your connections dry. This is why the manual says keep the “brick” 18” off the ground. If plugged in to an outside outlet, the outlet must be protected by a water resistant cover. This is one that protects the outlet from rain
when it has something plugged into it. This is different from the outlet cover that came with your house. These can be found at the big box stores.
Both outside and inside the garage (wet car from rain) the connection between the charger and extension cord must also be protected from water. Outside with a cover or inside off the floor.
And remember extension cords are not allowed to go through walls, be continuously flexed, or have doors/windows shut on them.
You should consult an electrician if you are unsure of any of this.
So you can use an extension cord with your 120v charger if you follow the rules. I did for several months before I got my 32 Amp Level 2 EVSE installed.
And BTW, you don’t need a twist plug connection. Even your electric dryer and range don’t need them and they carry much larger loads. Just make sure all connections are fully plugged in and in good working order.
Here is an example of an outdoor outlet cover and cord plug cover:
