Tommm
Is the Mini set up like every other modern BMW with a jack point under the front subframe and a jack point in the center rear? Those are what I use on my 1er, leaving the jack points free for the jack stands. Also, dont worry so much about the jack points. The plastic piece is readily available on line, and probably a buck each at a pick and pull since 99.44% are only used by shops.
https://www.amazon.com/AUTOPA-51718...pcontext&ref_=fplfs&psc=1&smid=A2MIOKJ0DJYQIH
