Looks
It looks great! I love how it looks.
Install
The install is pretty straight forward with no surprises. The front is especially easy since you don't need to compress the springs to get the top hat installed. It dropped the car 30mm as expected too.
The rear was more challenging. The rear springs are about the same length as the stock ones but compress a lot more when installed. It is difficult to get the spring put in place while making sure the bottom mount is lined up properly. I used a paint pen to mark things to make sure I was aligned.
The rear also calls for installing a 5mm thick rubber gasket on top of the rear springs. I couldn't get this installed so my car has a 25mm drop in the rear instead of the designed 20mm drop. The rear springs are from a Mini Clubman F54 and that installation guide doesn't include this gasket. I think it is there because the springs are designed to provide a lot of comfort being progressive and when you put two people in the back seat in the SE, it will probably sag too much. So, they added a 5mm shim.
Ride Quality
This is why I was trying the Eibach springs. I would like it to be smoother than what I have now. I found out that Eibach front springs are linear and the rear are progressive. This makes the ride a bit rougher than stock but not much. Overall, the Eibach are smoother but have a lot more rebound over bumps. So, I like the Eibach better at some things but worse at others. Here are my thoughts.
Interstate driving: Eibach wins. It feels like the stock suspension and handles those breaks between the road and bridges better than the coilovers. It also handles uneven roads caused by semi trucks. I didn't even notice this on one part of the interstate that I feel it with the coilovers.
0-30 mph rough road: Eibach is better at handling bumps like this but not as much as I thought it would.
Big dips in the road: ST coilovers are much better at this. The stock dampers with Eibach is probably like how the stock suspension gets unsettled when this happens while the coilovers handle it really well.
Back roads: ST coilovers wins. The Eibach springs are really planted in the front and feels really good in a tight turn but there is more body roll and if there is a bump in the turn, there is too much rebound in the suspension. The ST coilovers are really good on back roads. It is a lot of fun to drive. Even when driving normally on back roads, the coilovers are better. I was on a road this morning with a 40 mph speed limit which I was going. The dips and bumps in the road with Eibach springs caused the suspension to rebound too much.
Final Thoughts
If you want to lower the car to make it look better but don't really car about better handling, I would definitely get the Eibach springs. You'll be very happy. You'll also be happy if this is your daily commute car. It is really nice on the interstate. But if you mostly drive around town and on back roads or want better handling, get ST coilovers.
So one weekend in the near future, I'll be putting the ST coilovers back on the car and selling the Eibach springs.
