KiwiME
Here's an attempt to make the gear oil analysis data easier to read. All (9) 'no-magnet-added' first oil change reports so far have been incorporated into the iron and aluminium trendlines. The actual trends are by no means expected to behave linearly with distance driven but the lines provide a visual average of the highly-scattered data. The line widths are intended to improve clarity only.
For the individual reports, all iron (Fe) datapoints are squares and all aluminium (Al) datapoints are hollow triangles. The iron and aluminium values are paired by owner and those pairs ordered in the list by increasing drain intervals, noting that this value won't be the same as the odometer reading for reports of 2nd oil changes. Since each owner's report is at fixed drain interval the two associated markers happen to be on the same vertical line, making them easier to match up.
The datapoints really are surprisingly scattered and comments made by the laboratories on some reports indicate that these are "high" to "very high" levels. I'll note however that many of these reports read like horoscopes and certainly these vendors want your repeat business.
For iron it may be a matter of whether the stock internal magnet has any effectiveness since any fresh wear particles captured won't show up in the numbers. With an owner-added magnetic plug (or equivalent disk magnets) we should see those levels plummet, as has happened at line #3.
For aluminium it's anyone's guess at this point because we don't know where it's coming from. A cleanly assembled gearbox working correctly should not be leaving aluminium debris as all normal wear parts are made of steel. The aluminium itself is not harmful, it's only a matter of why it's present.
It could represent either casting flash or machining debris left during production, or more concerning it could be unintended bearing outer-race spin causing wear in the aluminium housing. The only other reason I can think of is erosion damage from oil circulation as sometimes seen in ICE water pumps. The highest aluminium value from a Leaf gearbox [of the (2) Leaf UOAs I have as references] is 130 ppm at 20,000 km which is about double the trend below. The lowest is 36 at 107,000 km, a trivial amount.
A related item that's caught my attention recently is that very occasionally we see a first oil change that is almost clear but with some black particles. The example pictured below is after 72,000 km on a 2019, reported on FB. I'm beginning to think that it's mostly or entirely the aluminium content that discolours the oil while the iron content may not.
