What year and how many total miles?Yes it does. It's referring to the Gear Reduction Box oil.
Check this out: Join me on my Kia E Niro's 1st Service - YouTube
Bruce, I have a 2022 Niro EV iwith 5,000 km and live in Yukon, Canada (cold in the winter). I have been looking for transmission oil for the gearbox oil change. I can't find any straight 70W - only 75W90. Do you have any opinion on using this oil which is GL-4?2019-2020 15,000 miles
Thanks for the suggestion, Bruce. We are well into autumn here and I prefer to go with the less viscous oil for the winter so I will change now. We have no Hyundai dealer here and I drew a blank at the local Kia dealer - they didn't know where to get the needed oil. So, I am left with the auto parts suppliers. Do you know what DCT and DSG stand for? And what is ALF-ULV besides automatic transmission fluid?Well, I sourced mind from the KIA dealer. They didn't ask why at the parts department. You can also get it at a Hyundia dealer. However, in the meantime I'd wait to change it after 15,000K
I'm the resident loudmouth for oil and gearbox stuff so I'll give you my $0.02.
You should be able to find Hyundia's 70W DCT at the dealer or order Redline MT-LV online, 1 litre or 1 qt is enough (only just). There are other DCT/DSG oils that might be locally available as well. Automated manual transmissions use thin oil to allow fast shifting. Around 5 cSt @100°C and GL4 is what we need.
But another option for the extreme cold is an ATF-ULV which I'd bet is off the shelf in your area. ATFs have a suitable GL4 gear rating and viscosity. Some low-temp Kona/Niro owners mention a whine when cold which is the result of oil being a bit too thick. I even get this at 7°C with the 70W-75 that I use, 7.5 cSt. The Hyundai oil is 5.4 cSt @100°C while a ATF-ULV is around 4.5.
But don't use a 75W-90 or anything close, they're way too thick. The high motor speed requires a thin oil.
This would be the best option, a good opportunity to keep an eye on things, at a relatively inexpensive cost.4. Do one oil change, add a magnetic plug then do further oil changes at some arbitrary interval ongoing, say 30,000 km or even longer.
That inspection at 24,000 km last week resulted in an oil change after only 4,000 km because it was annoyingly totally black. There was not too much glitter, just a perceptible sheen at a close look. The magnetic plugs were virtually clean but they had been wiped clean only 1,000 km before at an inspection.... My next inspection is upcoming and I expect the oil to be free of iron (magnetic plug installed) but tinted slightly due to the aluminium. I haven't had a UOA done as it's less convenient and more expensive here in NZ.
Same drive train, I would just order through Hyundai with the knowledge that these part #s work... who knows what part #s Kia might issue and may provide the wrong partsSo is there a different part number from Kia dealer for the oil and plugs? Or do I have to go to Hyundai dealer?
Oil - 00232-19063
Plugs - 00810-17121
Washers - 45323-39000
