My earlier post was cutoff by a dog demanding a walk, so here's one additional idea. Putting a sound processor between the factory amp and the speakers could help a lot with the compression of streaming audio, the output of the factory amp, and speaker quality. You may want to consider something like the JL Audio processor?
https://www.crutchfield.com/p_13698103/JL-Audio-FiX-86.html?search=car+audio+signal+processors
Thanks for suggestions, first step I just want to speakers only, hopefully not complicated. I listen to jazz and rock. Not looking for huge lows or loudness but more full sound. Source files are lossless files, we have HD radio stations that do not sound as they should.I am comparing to Bose in my Mazda CX-9. Does changing speakers alone make enough difference ? Which brand speakers performance will be step above factory? What price range etc
Especially post where you found the room for the amp and sub woofer and some details on how to remove the door panels with out damage. I would really appreciate that bit of info along with speaker makes and models and how you like them.I changed all the speakers and added a 10 inch sub amp and processor. I will post the specs and info soon. If any1 has questions inbox me Thanks
Maybe if you could 3D print the chicken?
Here are a couple of other threads on the audio system with some information that may help.
https://www.insideevsforum.com/community/index.php?threads/front-door-speakers.1248/#post-12973
https://www.insideevsforum.com/community/index.php?threads/clarity-speaker-quality.711/#post-10892
Word to the wise, don't start taking apart door panels or other trim without extra trim fasteners. You will break some, especially if you don't have others on hand!Especially post where you found the room for the amp and sub woofer and some details on how to remove the door panels with out damage. I would really appreciate that bit of info along with speaker makes and models and how you like them.
BTW, the 8 speakers in the Clarity's 180 watt sound system must be the 2 tweeters in the A pillars, the 2 woofers in the front doors and the 2 two-way speakers in the rear doors (which must be counted as 2 speakers each just because they have a tweeter and woofer in the same basket). So, replacing the front speakers would best be done with component speakers and replacing the rear speakers would best (easiest) done with two-way speakers.
