KiwiME
It's less of a mystery when you consider that the Bolt also uses the oil to cool the motor and therefore that likely explains the additional volume. The oil is drawn through a plastic particle filter screen with a pump, cooled by a heat exchanger and then sprayed onto the windings. As far as I know, the Bolt is maintenance free regarding changing the oil. The overall design seems well engineered, IMO. Yes, problems are extremely rare but not zero from my readings of owner's forum chevybolt.org.
The Kona/Niro/Ioniq/Soul and Leaf gearboxes are simple splash-lubricated design like a 1950s BSA motorcycle, so the volume has to be carefully chosen to balance effective lubrication versus losses from churning. The Leaf oil volume is about twice Hyundai/Kia but that appears to be more about gear size rather than any other reason to have more capacity. Leaf oil changes on YouTube don't show any hint of blackness at fairly high miles.
As I mentioned above, I'm tending to think that the blackness in the Hyundai/Kia units may be related to electrical discharge across bearings by small currents escaping the motor shaft, an artifact of high-frequency PWM switching leading to phase imbalance according my research. This better explains the odd mix of failures we see past simple wear, especially now that we know that a magnet is present. There's no way to evaluate this without having the motor/gearbox in a laboratory situation with a dynamometer. Interestingly the Bolt has no obvious grounding system but I have no doubt GM knows their stuff in this regard.
