Rexsio
I installed a temperature probe under a cover of engine /motor to monitor temperature inside a bay where every think is so compact is really no air circulations .That motor with plastic cover looks like all gasoline cars to cover all staff what is there .and keep HEAT inside .Havoc system on SE is the most complicated system of all EV’s .That car the most efficient temperature to run is between 70’ to 104’ but once you go over between 120’ to 130’ degree you fry a motor , hopefully the car shuts of .I NY is still cold but if get to higher temperatures I will try to monitor temperatures under a hood ,with motor cover and without.Why I’m try to engage members with this conversation bc in California people have already issues with hot weather when charging a SE .I show a pictures how I did my project a thermometer is plug in USB port /5 volt . Don’t explain all heat pump ,compressors etc. I know a staff how this works.
