Urbanengineer
I’m excited to buy a low rolling resistance tire when these Goodyears wear out the car came with. Happy new year to all.
Wait. Don't you activate the traction control every time you accelerate? I must be too exuberant.
Yep, finding the Vredesteins were difficult. Tire Rack ranked them high in wet braking and wet cornering, guess the Hankooks wet performance spoiled me enough to seek our a worthy enough contender. A P7 update would be great, we had the previous generation P7s installed on the Chevy Volt, offered significant improvements over the LRR tires from the factory, with a slight hit in efficiency. They also performed admirably in Minneapolis winters, but never jumped off the line.Tire availability is definitely an issue here in southern New England. Because of our increasingly mild winters and my reluctance to drive on snow tires during late fall and early spring, I opted for Pirelli Cinturato P7 A/S Plus 2 on lightly used Loop Spokes. The tires may not be best on ice but they get decent rolling resistance scores and are fairly quiet. Alas, I had to get them delivered to my local shop. A week later, I’m still waiting. My SE should be delivered early next week. I’ll offer a report on their performance but I won’t be able to compare them with the OEM summer tires for some months . . .
No issues as far as I can tell. You're right about the gap between the tire and the springs though, it's really close.Do you have spacers on? There is very little clearance (~1/8") between the shock and tire with the stock 205/45R17. Theoretically a 215 tire would be rubbing without spacers but some 215s are slightly less wide than the spec.
Anyone know how long tires can sit unmounted, and how many times they can be un-mounted/mounted?
Unless you're driving in an enclosed space, I don't see how it would be much of an issue.From that TireRack link:
Keep the tires away from sources of ozone. Electric motors that use contact brushes generate ozone.
Does this mean BEV drivers have yet another thing to worry about when it comes to tire life? Or are we safe because the motors are brushless?
I managed to drive on a dry, windless day with temperatures around 40 ºF (40 mile trip) and proved the Hakkapeliitta R3s on the Spectre Grey Revolites are extremely efficient. @GvilleGuy's MINI EV Range shows over 5 mi/kWh!
I believe I was driving in green mode and took a route that minimized freeway, so about 20-25 miles at speeds above 60 mph. It is on the high end of what I've been able to get out of the SE, but it's about the same as the best I can get on my 17" Power Spoke summer wheels with the stock Goodyear Eagle F1 Asymmetric 3 tires.Any highway driving in those 40 mi?! Any comparison to the stock tires? 5 mi/kWh seems extremely high
The SE's traction control is very aggressive to avoid wheel slip, especially for the instant torque of the electric motor. If you haven't yet, take a look at the traction control settings thread.Was not able to floor it from a light without traction control cutting in, which was a bit disappointing, but totally understandable.
Just had my first real driving experience with my VikingContact 7s in 30F (ambient) wet weather. Was not able to floor it from a light without traction control cutting in, which was a bit disappointing, but totally understandable. Being my first set of winters and EV, I was not sure what to expect. Needless to say the Tesla next to me, uh, won. Blaming it on the tires
Turn in and corner grip on 30F damp roads was not noticeably worse, at least for moderate driving (not what I would consider spirited, but by no means docile). Maybe a bit more numb on the steering feel though.
Otherwise, the VikingContacts are reasonably quiet (we are not car reviewers, but it was not a noticeable increase in noise), without any noticeable increase in consumption. Once I get some highway mileage on them, I will report back on the efficiency.
Took the Mini out for a test today and was pleased with the performance of the Continental Procontact LS tires. About as well as a front-wheel-drive car can do with A/S tires, I think. My alley (pictured below) had a few inches of compact snow and ice and I chose to go the "hard way" up hill and encountered no slipping and no trouble stopping at alley-speed (under 10 mph).
I did some driving in the local school parking lot and again had no trouble at slow speed, even trying to spin the tires and whip the car around a bit. It was about 1.5" of snow atop an inch or so of compacted snow and ice.
Further away in other areas where the compact snow and ice lingered, the car/tire combo still performed as well as I could expect without dedicated snow tires. I'm confident that it would handle fresh snow and slush very well and only struggled with the actual layered ice. Happy with my choice.
Rob
