Actually, the Clarity Plug-In Hybrid is on a fuel-cell platform rather than an ICE platform.Sell it and get a real ev from a manufacturer that makes electric cars and not some compliance afterthought on an ICE platform.
Don't know what year of your car, but in mine (2018) is the sign of the 12V battery need to replace. So check the battery voltage if under ~12v. Temporary fix is jump start or use car battery booster - goodluckView attachment 14418 Very strange. Out of no where this error message popped up, "electric parking brake problem". But the electric parking brake works fine. Any suggestions what to do?
Good info, will check on that. Mine is 2018 as well. Was gonna take the car to the shop for check up but the error showed up in the app for 2 days and went away. Yep always carry the jump starter and spare tire in the trunk just in case.Don't know what year of your car, but in mine (2018) is the sign of the 12V battery need to replace. So check the battery voltage if under ~12v. Temporary fix is jump start or use car battery booster - goodluck
What kind of jack do you carry for your 2-ton car? I foolishly tried the electric jack I'd been using for years with my 1,850-lb Honda Insight. I'm glad it failed before I got the wheel off. Smart people always use jack stands for safety, but I'm not one of them.Good info, will check on that. Mine is 2018 as well. Was gonna take the car to the shop for check up but the error showed up in the app for 2 days and went away. Yep always carry the jump starter and spare tire in the trunk just in case.
Oh geez, sorry to hear that. I used to carry 2.5 ton hydraulic jack and didn't feel the need for it. Now I only carry a small scissor jack + small spare donut wheel.What kind of jack do you carry for your 2-ton car? I foolishly tried the electric jack I'd been using for years with my 1,850-lb Honda Insight. I'm glad it failed before I got the wheel off. Smart people always use jack stands for safety, but I'm not one of them.
Nice jack--much nicer than the ones you have to crank. Do you have a Honda donut so you did you find a non-Honda spare that works with Honda's lugnuts?Oh geez, sorry to hear that. I used to carry 2.5 ton hydraulic jack and didn't feel the need for it. Now I only carry a small scissor jack + small spare donut wheel.
Link for scissor jack: https://www.amazon.com/Wheelpal-Scissor-Capacity-Trolley-Ratchet/dp/B08TMRRNCL/ref=sr_1_4?crid=LN0CHLYUOL79&keywords=wheelpal+scissor+jack&qid=1639859247&sprefix=wheelpal+scissor+jack,aps,130&sr=8-4
I have the Infiniti donut tire. Which fits PERFECTLY on the Clarity no mods needs it. OEM Clarity lug nut fits right on it.
Hmm, I see what you are saying but fit perfectly fine with OEM Clarity lug nuts. Drove around the town no issues so far.Unfortunately, the Infiniti spare shown in the pic above above comes with conical lug nuts and the Honda uses ball lug nuts. I copied these descriptions to help:
"Conical wheel nut feature a straight taper at the seat area. Conical fasteners are also called “tapered” or “cone” types.
Radius seats are also called “ball” or “rounded” seats. As the name implies, the seat features a radiused “ball” shape that nestles into a ball-shaped pocket in the wheel.
The golden rule, when discussing seat styles, is extremely simple: Never mix them! If a wheel is designed for conical 60-degree seats, the only fastener seat style that can be used is a 60-degree conical type. The same rule applies for radius and flat seat styles."
So you really should get a set of 5 conical wheel nuts to use with the Infiniti Spare.
BTW, not all of the Infiniti spares use conical lugs. I've seen a few with Mag type lugs (same with the Nissan Wheels).
Also, the Infiniti wheel in the pic fits a 66.1 mm hub. The Honda wheel fits a 64.1 mm hub. You really should use hub centric ring adapter of 66.1 mm to 64.1 mm with this wheel.
Absolutely. Anything that's better than what Honda gave us, just an air inflator. One needs to be creative vs stuck in the middle of the road.Just because you can do a thing doesn't mean you should do a thing. I wouldn't trust driving far or fast with the wrong lug nuts on the wheel. I'm not as strong on the hub centric adapters, but it seems that the wheel should mimic the OEM fit, so I made that happen with aluminum hub centric adapters JB- welded to the aluminum rim so that the wheel fits flush on the shallow hubs of the Honda, just like the OEM (Nissan and Infiniti have much deeper hubs and fit "deeper" in the wheel). You are right that there are all kinds of opinions on the "need or worthlessness" for hub centric adapters.
Damn, post a pic when you r done with that old school beauty.We only carry the spare for out-of-town trips (which haven't occurred often since the pandemic) so I also bought a "storage rack" for when the spare is in the garage.
It has no engine, therefore I assume you plan to electrify that thing ??![]()
