Very weird. I thought I saw the warning in the dash but not 100% sure. As of now I don't see this error on the dash except the darn Honda link. It's sad this car only has 7k miles on it.Do you also get this same warning on the dash?
I am not a big fan of HondaLink and wondering if there is a bug there rather than in the vehicle.
If you do have the same warning on the dash, then you could go to the dealer and have them check for Diagnostic Trouble Codes (DTC''s). If a DTC is present, it may shed more light on exactly what the problem is.
If you have no observable problem that you can relate to this, then it may be reasonable to wait for a while. Some trouble codes will clear themselves after a few drive cycles, and it could have been a transient issue. If it does persist, then checking for codes would seem warranted.
Car parts stores will also do a free check for codes too, but I am a little skeptical as to how comprehensive that check would be with a Clarity because of all the specialized EV electronics. If it were the standard emmissions-related codes, they can probably do OK, but I think the dealer has a better chance of properly diagnosing a Clarity.
I wish Honda gave me the old school parking brake and call it the day. Definitely not worry much but it'll be a trip to the dealership it's a hassel. Thank God it's under warranty.Not to worry !!
This sounds minor to me.
We have many members in this forum, and from my perspective, the Clarity has a very good reliability record.
In an emergency, I’d certainly prefer electronics and switches and logic modes not be involved.
It could be why it’s now called a parking brake, since attempting to use it in an emergency may result in an undesirable outcome. The only options are “On” and “Off”. There’s no way for the driver to modulate the braking force.
Then there’s the brake pedal to consider.
I don't know if it would be possible, but one thing I would try in that scenario if the parking brake didn't respond while in motion would be to pull back on the Reverse shift button. Maybe nothing would happen, but if it was that critical a situation—and there was time—I'd try it and worry about drive train damage later.What happens in an 'emergency' scenario when the servo brake system has failed? One would hope that the parking brake would be applied while moving out of necessity. It would be very nice to know what to expect before actually needing to do this !
I think I had this issue in my car - very early on so more than two years ago. Software update at the dealer fixed the issue.
