I set one quick preset to my radio preset list, and you can set many stations mixing the bands in the radio preset list. Then you can use up/down arrows on the steering wheel to select, or use the menu.Is there a way to have six presets for each band?
The MINI SE is almost perfect in my book. I only have a couple of very small gripes.
3) Run flat tires should be an option. The factory obviously has RF tires in the correct size in stock, so making them an option should be simple enough.
When we picked up our car and the dealer was explaining the tire repair kit, he said that the SE hasn't been coming with runflats because they haven't found any that work 'right' with the regenerative braking system. I'm not sure exactly what 'right' means as I didn't ask any questions, but assuming he's right that'd be why.
Wow... that's probably the craziest thing I've ever heard from a dealer! He probably just blurted out the first thing he could think of that was unique to an EV.
Regenerative braking is no different than regular braking from the tire's point of view.
Well, with regen, the car can go from accelerating to decelerating and back much quicker than with friction brakes, so that is a difference.
Run flats are known to reduce gas mileage on ICE cars so the SE would probably take a pretty big range hit if equipped with them. My guess is they couldn't find run flats efficient enough.
