Ioniq 5 - Living with the Car of The Future
  • Thread starter Thread starter restyler
  • Replies Replies 59
  • Views Views 18K
Not had any issues with the key not being detected, if indeed that was the cause of that problem - also not seen this mentioned on other I5 forums.
He also mentioned earlier about auto parking not working.
Well I've not tried this out personally as these systems are always too slow, but I've seen lots of videos of it working & it doesn't look like this guys doing it the right way.
The issue I'm most concerned about is what he experienced with the power being reduced after a rapid charge. I gather he did a fast high voltage charge from 10% to 80% and when he jumped on the highway after, only had partial power available.
For some reason they are limiting the towing capacity in the USA market to 1500 pounds or just 682 kg. The V2L will be 1.9 kW where I believe you have about 3.8 kW available. Not sure why. The Ioniq 5 is still not available here but hoping to see some by the end of the year. It seems like the only option for Range, fast charging, V2L ability and some towing capacity.
The output is likely limited by amps rather than power. In UK it’s 230v x 16a = 3680W. Presuming the USA will be 110v x 16A = 1760W.
The output is likely limited by amps rather than power....
Correct - I did the calculations below & came to the same conclusion
European Household Voltage = 230V
I think we can output 3.6kW
Watts = Volts x Amps, So Amps = W/V = 3600/230 = 15.6 Amps
USA Household Voltage = 120V
Therefore if the NA V2L can output 1.9KW, A=W/V = 1900/120 = 15.8 Amps
The safe current capacity of a cable is down to its cross sectional area, ie - the thicker a cable the more current it can carry.
So its reasonable to assume that the cables leading up to the V2L socket on the car are the same thickness for all markets, being designed to not carry more than around 16 Amps
So, how well does the "Car of the Future" drive itself autonomously?
Spoiler:- It's not as good as a Tesla, but there again, Hyundai never promised me FSD ;)
Thanks for posting the video Restyler. My Kona shows two green lane lines once it engages and this happens at a minimum of 64Km/h ... is it the same in the Ioniq 5? Cheers, Steve
Yes, if that's Lane Keep Assist or Lane Follow Assist, the minimum speeds seem similar.
Just checked this in the manual, & its probably the reason why I couldn't get it to work on some lined country roads when I was going around 25mph
See if this link works for the online user manual (P.397 shown above)> https://uc7fbc779516da7724267c72935...70buBgv99wSGJNS7ye-lyrL3552kLFPBJlF8qUo/file#
Because they have 220v in Europe, and we only have 110. We only get 220 with 2 phase, and they apparently can't do that.
You have 240VAC split phase domestically, single phase with a center tap to provide 120VAC in two 180° out of phase circuits.
