I managed to get one of the first edition Project 45's - very similar to yours but with 4WD
I'd rather have the sun roofPresently adds around 6 miles per week in UK - better than nothing![]()
Autoblog writes: Hyundai Will Use SK Innovation Battery Cells for the Ioniq 5What brand battery is used in IONIQ5?Is it LG or SDI?-----------deeks
It all looks very promising so far.........It will be interesting to see if they have any of problems that Elon mentioned going forward.
For some reason they are limiting the towing capacity in the USA market to 1500 pounds or just 682 kg. The V2L will be 1.9 kW where I believe you have about 3.8 kW available. Not sure why. The Ioniq 5 is still not available here but hoping to see some by the end of the year. It seems like the only option for Range, fast charging, V2L ability and some towing capacity.
Correct - I did the calculations below & came to the same conclusionThe output is likely limited by amps rather than power....
So, how well does the "Car of the Future" drive itself autonomously?
Spoiler:- It's not as good as a Tesla, but there again, Hyundai never promised me FSD
Yes, if that's Lane Keep Assist or Lane Follow Assist, the minimum speeds seem similar.My Kona shows two green lane lines once it engages and this happens at a minimum of 64Km/h ... is it the same in the Ioniq 5? Cheers, Steve
You have 240VAC split phase domestically, single phase with a center tap to provide 120VAC in two 180° out of phase circuits.Because they have 220v in Europe, and we only have 110. We only get 220 with 2 phase, and they apparently can't do that.
