Carsten Haase
On my car this toggle deactivates the sound in both forward and reverse, for the duration of the drive only. Then it defaults to back on.
I remember mine doing that too but only the first time I select deactivate. The "remember" setting only seems to remembers the choice to disable it when going forward so after one shutdown the reverse noise comes back but forward does not.
The car threw a bunch of warnings while it was coding the seatbelt changes, but they went away after restarting the car a couple times.
Same here (I probably should have mentioned that). Any setting that reboots a safety system ECU makes the car panic and set a bunch of codes. Once you restart the car it realizes everything is fine and the errors go away.
