Same here Ken7. It charges so quickly that after arriving home and plugging the power cord into the car we hardly notice before it's ready to go again. Just have lunch, check email, and a few other things and the car is back to 100% charged.I get a full charge from a fully depleted state, in about 2 hr 5 minutes.
Yes, it's the Honda app. It works okay - most of the time.Does charge point show you the charge amps/rate? My home chargepoint EVSE does. The only thing I notice is when the battery is cold it charges at about 4 kw. At normal battery temperatures it is 7.1 or 7.2 kw.
Is that the Honda App? My wife complains about it a lot. The ChargePoint app should tell you the rate its charging. The 2 hr 40 min might be a bug or something.
Eric
Ken, how did you get the grease in the holes and did you put it in all the holes? I'm wondering if this inhibits, in any way, the current flow.View attachment 515 Only has my Clarity for 6 days and just got my ChargePoint.
I think I have the definitive (hopefully) answer for the folks whose charging handles are hard to insert and remove.
It’s clear that the o-ring is there to seal out moisture and engages toward the end of the insertion travel. This it is not the reason for any initial/halfway hard to insert/remove problems. Greasing the o-ring gave me a slightly easier end of insertion and beginning of removal effort.
But here is what really helped:
I put some dielectric (non-conducting) grease in the holes of the charging handle (first turn off breaker for safety). I did this primarily to protect contacts from corrosion and also to ease insertion/removal effort due to age and old arm injury. And it worked! Much easier that before. Think about it. The electrical contact between handle and car must be a tight friction fit to prevent arcing so it makes sense that it is going to require some kind of effort to mate up. Usually it’s not to bad but I have one public charger that a bear. Unless your handle is out of spec (SAE J1771) this should make it easier on you and keep you from having to remove the o-ring (think lawyers/insurance claim). You can purchase the dielectric grease at auto parts stores and use it on the o-ring as well. Please try this and let us know it it helps more people than just me.
Hope his helps and consider it my thank you for all great info I have found in this forum.
Slightly related question: What is the length of the included 120v charger? Thank you!
I recently install Lectron 32A level2 charger. It's seems to be running fine but the meter only shows 14-16A. Can Clarity handle 32Amps?
Something is not right. The Clarity will draw ~30A @ 240V (~7.2 kW).I recently install Lectron 32A level2 charger. It's seems to be running fine but the meter only shows 14-16A.
This is not how you measure 32 amps... It should have 32 amps in each of the wires on 240vI would fully expect a reading of 14-16 amps flowing thru each 120v leg of your 240v circuit.
Added together you’re flowing 28 to 32 amps...
Yeah, there are no 120v ‘legs’ because neutral is not used by the EVSE. You can measure current on either L1 or L2 and it will read the same. Do not add the values together.Define “meter” and how you are using it to get your readings. I would fully expect a reading of 14-16 amps flowing thru each 120v leg of your 240v circuit.
May be simple error in how you are hooking up your meter and/or interpreting the results.
