Really happy to see this thread bumped. I've taken everything I learned here (special credit to Fastnf and Kiwime) and very slowly pieced together a solution over the years, or so I hope. No electrician would help me plan, nevermind do the whole project for me so I decided to try it myself. Would you guys mind gut-checking my rookie outing?
Starter battery -> 70A fuse -> 50A DC-DC charger with total 3 feet of 4 AWG wire
I got a second identical 50A DC-DC charger, same as above.
2x DC-DC chargers -> 70A breakers -> 100Ah LFP battery with total 3 feet each of 4 AWG wire
LFP battery -> 250A breaker -> 3kW split-phase inverter with 1.5 feet of 0 AWG wire
Inverter -> 30A house panel breaker (interlocked with mains breaker) with 30 feet of 10-3 Romex wire, ground to neutral bus bar
The two DC-DC chargers supposedly have mid-90% efficiency, so the Kona should survive even a 2x 50A draw for some time. Downstream from there, the LFP battery can discharge at 100A, so altogether this setup can send 200A to the split phase inverter. I'd like for this setup to power a 700W to 1300W sustained and 2000W peak AC house load.
Voltage drops average around 1%. Different wire size charts gave me different answers, but I feel pretty comfortable with the setup. Or, should I not?
Penny for any and all you guys' thoughts and advice, as always.
Sent from my ONEPLUS A5000 using Tapatalk
