F14Scott
In a gas car, going hammer down from a stop introduces all kinds of inefficiencies:
Less than ideal mixture
Less than ideal timing
Less than optimum RPM range
Operation in less than top gear
Need to grossly cycle throttle to facilitate gear shifts
Probably others I haven't thought of
So, spirited acceleration in an ICE = low MPG.
But, in a one-gear EV with a perfectly flat torque curve, I'm having a hard time picturing why a WOT run to 60 MPH would be appreciably less efficient than an easy-does-it acceleration to the same speed. Maybe the battery has an optimal discharge rate range?
Am I right? Can I launch hard with range impunity? I need data...
