I would like to clarify some confusion about software / versions as it relates to the AP200.
This is based on my observations and not anything directly from Autel, but I think it is mostly right...
First, it is necessary to identify the different pieces.
There are 4 pieces to the AP200 system:
1. The Vehicle Connection Interface (VCI). This is the AP200 itself that connects to the vehicle
2. The App(s) on the phone. This is the MaxiAP200 that you obtain from the Play Store.
3. During install, MaxiAP200 will also install another App ('diag-asia').
4. The Diagnostic code that gets installed for the vehicle(s) you are working on.
Versions:
1. The VCI contains firmware. This firmware is updated occasionally by the MaxiAP200 App. This occurs when you are running the App, have MaxiAP200 connected to the vehicle (with the AP200), and to the Internet. You will be informed that the VCI firmware is being update. To see what your VCI firmware version is, go to "Me" and select "VCI Manager". Here is an example:
2., 3. The two Apps (MaxiAP200, and diag-asia) update just like any other App from the Play Store. Autel will occasional release a new version, and depending on your phone settings, they will auto-update or not. MaxiAP200 may also recognize that an update exists and offer it to you, I'm not certain of this. The versions of these two Apps are always coupled together (they are both always the same version). To see what version you have, go to "Me", "Settings", "About". Here is an example:
Notice that my version is 1.36.
The current versions for a new install in the Play Store are 1.41. I have chosen to not update for now.
4. Finally, and most importantly, there is the Diagnostic Software. This is what gets installed when you select a vehicle(s) that you want to work on (in this case, Honda). It is not really software, but rather a database used by the application to know how to interact with your vehicle. You can see this on the main diagnostics page, and here is an example:
Note that the 'Eobd' and 'Demo' are free parts of the AP200 system that includes the standard mandated OBD2 emissions-related functions.
Most Importantly - You MUST have version 2.01.54 as shown above for the Honda Diagnostics. This will start out as version 2.01 when you install it. It is the beta upgrade that brings it to 2.01.54.
