Daniel Neumeister
Yes I just picked mine up this week and didn’t hear a word about any of this .. how can you tell when your battery pack was made ?
Read the attached label on the back of the pack behind the rear suspension on the drivers side, it has manufacture date, part# and BMS ROM ID.Does anyone know how to determine the manufacture date of a Kona battery?
Also, do we know if some form of mitigation occurred for batteries manufactured after March 2020 that renders them not included in the recall?
Good to hear, should replenish the resale value as well as confidence.
Sure enough it's right there where you said it would be. April 20, 2020. Thanks so much. Looks like I'm in the clear (this round at least)Read the attached label on the back of the pack behind the rear suspension on the drivers side, it has manufacture date, part# and BMS ROM ID.
Nothing in writing on your second question other than the manufacturing issue was found and presumably repaired as indicated by Hyundai.
Question is how long it will take for them to replace all those batteries.. Could be years..Good to hear, should replenish the resale value as well as confidence.![]()
Unless yours fails, then a lot sooner.Question is how long it will take for them to replace all those batteries.. Could be years..
A Canadian report of the recall is at https://canada.autonews.com/recalls/hyundai-will-replace-battery-systems-11b-global-ev-recall. LG is saying that the problem is not caused by the cells themselves but because "Hyundai misapplied LG's suggestions for fast-charging logic in the battery management system", which would perhaps explain the BMS recalls but not the battery replacement unless Hyundai suspects damage may already have been caused to some in-service batteries. The recall applies to vehicles built between 2018 and 2020. At a guess, those built after March 2020 may be in the clear, but we wait for more info.
There's an interesting number buried in this report. Others on this board have said the cost of a new battery is $30K. The link above says the recall involves 82,000 vehicles, of which 76,000 are Konas, with the rest being Ioniqs and a few city buses. The estimated cost of $1.1 billion should include the labour for replacement and the costs associated with reusing or recycling the old batteries. It works out to an average cost of around $13,500 per vehicle.
I didn't notice reduced range from the updates.. Still charging to 100% and 4.17 volts per cell..Hmm.. in the article, it said the BMS update limited our charging to actually 90% of the battery. I don't recall this happening, as I think I've charged to 100% without noticing any range degradation. Did others notice anything?
I fast charge A LOT.. No issue at all after over 135 fast charges.. This is my estimated range right now..A Canadian report of the recall is at https://canada.autonews.com/recalls/hyundai-will-replace-battery-systems-11b-global-ev-recall. LG is saying that the problem is not caused by the cells themselves but because "Hyundai misapplied LG's suggestions for fast-charging logic in the battery management system", which would perhaps explain the BMS recalls but not the battery replacement unless Hyundai suspects damage may already have been caused to some in-service batteries. The recall applies to vehicles built between 2018 and 2020. At a guess, those built after March 2020 may be in the clear, but we wait for more info.
Luckily, there is no OTA updates.. If there is an update to limit charge to 90%, I won't do it.. I go on road trips from time to time and need the full range occasionally.Given the significant time it will take to carry out this campaign I would not be surprised if Hyundai take some advantage of their goodwill and impose an interim SoC restriction as GM have done with the Bolt. It would make sense from their perspective to minimise any further bad news and liability.
EDIT: apparently this is already the case in S. Korea, 90% max.
It will be interesting to see what GM comes up with for the Bolt since their BMS may be different.
That raises a question (that may be a stupid one): is the 90% limitation only for DC fast charging or does it also include L2 charging on home chargers?Luckily, there is no OTA updates.. If there is an update to limit charge to 90%, I won't do it.. I go on road trips from time to time and need the full range occasionally.
I agree, it would be a confidence booster for Bolt owners if GM "joined the party". I guess we will see just how serious GM is about it's electrification goals.Given the significant time it will take to carry out this campaign I would not be surprised if Hyundai take some advantage of their goodwill and impose an interim SoC restriction as GM have done with the Bolt. It would make sense from their perspective to minimise any further bad news and liability.
There was no qualifier on that directive reported in the news, apparently for S.Korean owners. As with the previous actions for campaign 196 taken early last year, it will take at least a week for our respective country's importers to formulate their position and notify us. In my case it was a phone call about a week later.... is the 90% limitation only for DC fast charging or does it also include L2 charging on home chargers?
... LG Energy Solution told Reuters Hyundai had "misapplied" its guidance for setting up the fast-charging system
