Lucien Mcleod
Anyone know if there is a way to disable the low speed sound coming from the clarity. I installed a subwoofer and it is distorting the sound everytime it plays.......
Help
I am In The
I am In The
Absolutely right. With windows rolled up I can’t hear it.I don't think it comes into the cabin through the car speakers. It is an external sound only.
View attachment 934 The manual calls it the Acoustic Vehicle Alerting System. So I looked at the two fuse compartments on passenger side of engine bay and the diagram on the driver’s left foot kick panel and was hoping to find something like AVAS but no luck.
On the plus side I did find that we have several empty fuse plugs under the dash for things like dash cams (mine’s on the way). Will have to get out the VOM to find one slaved to the ignition.
I was reading a bit about the active noise cancellation in the Accords and it specifically mentions that it uses the subwoofer and shows a lot of activity around 100 Hz (10 dB in fact). Since this noise cancellation would seem to be most pronounced at low speeds just like the alert tones could it be that this is the problem?Which fuse controls the " low speed sound"
I thought that was in place to protect an unsuspecting pedestrian from being run over by our super quiet rides - isn't that more important than some sound distortion at low speeds?
There is a fuse box behind the charge door open button too. It is hidden so you will need to pull out the panel. That is a even a empty connector that you can use to get power. That is what Honda instruction said to use for adding ambient lighting.View attachment 934 The manual calls it the Acoustic Vehicle Alerting System. So I looked at the two fuse compartments on passenger side of engine bay and the diagram on the driver’s left foot kick panel and was hoping to find something like AVAS but no luck.
Thanks.There is a fuse box behind the charge door open button too. It is hidden so you will need to pull out the panel. That is a even a empty connector that you can use to get power. That is what Honda instruction said to use for adding ambient lighting.
If you are blind it does not really matter how big the car is.I was never sold on the idea of needing a sound to alert pedestrians of your car. The Clarity doesn't float above the ground. I would argue that driving at low speeds the Clarity makes as much noise as any other newer car. A regular hybrid doesn't make any engine noise at low speeds, either, but they don't have any exterior sound. If you run into anything as big as a car while walking I would say you need to pay more attention anyway.[/QUO
