Kwathouer
The comments to this article at avweb gave me quite a chuckle. Some smart people there.
Go down to a floatplane base, and watch a few planes take off. You will hear a very loud high pitched rapping sound as they reach full throttle which will last until they climb out and throttle back for cruise. That noise is created as the propeller tips reach near the speed of sound.
www.faegre.org › files › AF-seaplane-noise-2002
Dec 15, 1995 - The majority of the noise coming from a propeller aircraft is created at the tips of the propeller; there is not much coming from the exhaust pipe. ... Finally, a 10% increase in distance between the seaplane and the noise sensitive source results in a decrease in the sound level received by 1.0 dBA
Yes, that is very true actually. But even single electric motors can have longer propellers (more efficient) that turn at lower rpm. The problem with a smaller piston driven airplane is that they need 2700 rpm (low by car standards) to generate full power, and are equipped to provide the longest prop possible (most efficient) that does not have a tip speed too close to the speed of sound.Thanks for the articles RP. With electric flight, it is just too easy to have dual or triple rotors, running at a lower speed. Hopefully that will generate less tip screaming.
Further to the Harbour Air test flight from last Dec, this latest article reveals that only 15 minutes of flight with 25 minutes reserve is available. Seems they need to increase that a bit more before flights between the Island and Mainland become feasible.More info on first flight, batteries, and when pax service expected.
https://copanational.org/en/2019/12...dium=email&utm_campaign=COPA+eFlight-20191212
I am pretty skeptical of Dahn's work - as to their impact on the commercial products. Lithium-ion has improved only 3% in the past decade, and after reading some of his papers, I believe his practical improvements is less than 10% in energy density. Thus they will never see the light of day, as there is a huge chasm between lab work and a commercial product. The improvement in batteries will most probably come from solid state batteries and lithium-sulfur batteries. Neither of which he is working on, AFAIK. Interesting RP, you are in Vancouver? So am I.Still looks like a good application for this new technology with these short haul flights (30 minutes). Hopefully they will soon find a battery that will meet these requirements.
Yeah, the progress is never as great as the promise. I have had electric bikes for 5 years now, and looking back at the battery packs I bought back then, they still cost the same, and do not have any more power for the weight.
Yeah, that plane works as trainer, as most flight lessons are only 1 hour. But after that they still need to recharge it, which likely will take a few hours at least. So again, not the most productive flight school airplane. I am actually a pilot, if you haven't guessed so far.Is there a way I can DM you on this board?
I think for lighter aerodynamic airplanes, it is possible to have them electrified. The Pipistrel Alpha electric, the only one in Canada which resides in the Pitt Meadows airport will fly 2 hours, and is a great trainer. There is video of it flying on UT. I am also thinking of doing the same, but starting from a kit airplane, and building the power drive myself.
I hope they do well with their research and development, but I and probably many others would feel a little less than secure knowing that any kind of problem cooling and maintaining that liquid hydrogen at -423 degrees F would result in disaster.Hydrogen powered airliner in 15 years?
https://www.avweb.com/aviation-news/airbus-launches-hydrogen-based-zeroe-initiative/?MailingID=458
Yeah, no easy answers, same can be said by for LiIon based batteries (fire danger) in the air. But glad to see they are working on it, and will see what works out in the end.I hope they do well with their research and development, but I and probably many others would feel a little less than secure knowing that any kind of problem cooling and maintaining that liquid hydrogen at -423 degrees F would result in disaster.
https://www.sciencedaily.com/releases/2016/06/160616105904.htm#:~:text=Hydrogen droplet size affects the mechanism of burning,-Date: June 16&text=Modern rockets and their launch,self-ignition of such mixtures.
These are the same guys that were behind the Harbour Air Beaver test back last Dec. Seems like hydrogen and electric can make it happen sooner for the airline sized planes.
Hi R P - hope all is well, given that woman Henry the Rabbit who is trying to infect us all.So why are all these large corps working on it? Are they just trying to throw away their R&D money?
