Ronny
Mine took 65 minutes.When I took it in they said 45 min. but that turned out to be only the first stage. It ended up being 2-3 hr.
The minimum battery module temperature needs to be over 25C to get maximum power. I read on other posts that power might be limited with high battery temp, like 35C which I never reached here in Montreal.Would have been nice to capture the battery temps with TP before and after the update, maybe research that.
I don't have TP, and when fast charging (very rare) its never over 50kw.
That's to be expected.. The update will reset anything related to the battery to factory default.. so the range will be the factory default range.. Once you drive 200 - 300 miles, it will adjust back to where it was.Just had the update done this morning. I waited probably about an hour and a half. Apparently the service tech also did a comprehensive check of "inspection points" like lights, horn, fluid levels, battery terminals, tires, etc., all presented on a check list. I went in with SOC at 38% and got it back at 35%. Prior to this service, I've been charging to 80% and getting a GOM reading of around 260 miles. I'm now charging to 80% and see that the system thinks that 234 miles will be charged. As others have noted, the option to charge the 12v battery disappears.
Now lets see...conversion to Island time... yep- 2 to 3 hours sounds about rightWhen I took it in they said 45 min. but that turned out to be only the first stage. It ended up being 2-3 hr.
Report from Europe on password to enter engineering mode after update - the # is 2900 (still need to press the 5 taps right and 1 tap left of update)
