Things i dislike about the Kona
Discussion in 'Hyundai Kona Electric' started by victor_2019, Jun 30, 2019.
  1. electriceddy
    electriceddy Well-Known Member
    Very well done , thanks for the link.
    One question, when you pulled the switch panel left side of the dash, you said the VESS wiring was there but no button. It is my intention to add a momentary contact switch off pin 7 c/w a 200 ohm 1/4 watt resistor to ground to temp disable the VESS sound as indicated here:
    https://insideevsforum.com/communit...al-engine-sound-system.5821/page-6#post-78003
    (see the link to mikeselectricstuff diagram). Does this make sense to you and is the diagram and wire colors/ pin config the same as your tech manual?
    Also how hard was it to pull the lower dash as I can't contorty myself to get under there to remove the switch module.
    BTW there is a thread about modifications :
    https://insideevsforum.com/community/index.php?threads/modifications-and-tweaks.5009/
    Do you mind adding your link
    https://insideevsforum.com/communit...dislike-about-the-kona.6079/page-3#post-80335
    to this thread as it would be easier to find ,
    Thanks... electriceddy
  2. hobbit
    hobbit Member
    I've read about the switch-and-200-ohm thing but not looked into it for
    myself so far. I don't understand why the resistor would be needed, as
    it is a separate switch on its own and not part of a resistor-ladder
    matrix like the lights or audio. Maybe they force it to be "ladder style"
    to detect shorted conditions or something?
    I'll update the other thread as well, thanks for the encouragement ... I've
    got a bit more in the pipeline, too. I'm actually looking for other Kona
    forums where the most tech-geeky owners hang out, to possibly join...
    I know about mykonaev.com and speakev.com and a couple of others
    but it's hard to tell where the richest content might be.
    _H*
  3. EVRIGREEN
    EVRIGREEN New Member
    Just a small thing, but I don't like it that the radio doesn't shut off when I turn the power off. I've actually left the car on by mistake more than once because of this (and an annoying beeping sound lets me know). If the radio turned off, then I'd know the car was off.
    Tony M. likes this.
  4. XtsKonaTrooper
    XtsKonaTrooper Active Member
    The button shifter is wicked for reversing and getting going fast.
  5. Chris-Ca
    Chris-Ca New Member
    Mine turns off when I put it in park then open the driver's door.
  6. Francois
    Francois Active Member
    I dislike how aggressive (2 or 3 email, along with 4 phone calls in just 2 weeks) SiriusXm is in trying to get me to subscribe to their service even though I still have 3 months to my free trial. I know that is not technically the Kona's fault but I never had SiriusXm before the Kona so....
  7. Francois
    I also dislike that when I turn on the heating of the steering wheel, it is the whole steering wheel that is heating up instead of just the two spots where your hands are supposed to be (at 10h10) if the steering wheel was a clock. Heating up the whole steering wheel is just a waste of energy.
  8. XtsKonaTrooper
    Tell them to stop calling and then block their number.
    They are worst than bill collectors.
  9. Esprit1st
    Esprit1st Well-Known Member
    It's easy. Log into your account on their website and go to preferred contact options. Disable phone and email it whatever your options are and you're good to go.
    Your hands are supposed to be at 9 and 3 o'clock. But when you turn and grab over and grab a different position your hands would freeze into place. That's why they heat the whole wheel.
    TheLight75 and electriceddy like this.
  10. ericy
    ericy Active Member
    The 10 and 2 was what they taught us before there were airbags. If you get in an accident and your hands are 10/2, you will likely end up with broken wrists.
    I had Sirius in my old car, so I just transferred my plan over to the Kona. Every so often I call up and ask to cancel. The reason given is that it is too expensive - they immediately come up with another plan which is far cheaper. I wish the cable companies would roll over this easily.
  11. Francois
    Some of us remember a time before there were seat belts even. :)
    I never knew the recommended position for the hands was changed to 9/3. Will be hard to change a lifetime of driving at 10/2. Might just be easier to disable my airbags. ;)
    Esprit1st and XtsKonaTrooper like this.
  12. KonaTom
    KonaTom Active Member
    HaHA. I think 8 and 4 is a better position as 9 and 3 is difficult to hold on properly because of the wheel spoke. Also the heating works at 10 and 2 and 8 and 4 mainly.
    R P likes this.
  13. Francois
    At 8 and 4, the point of your elbow is facing downward which might impact your ability to do a sharp turn rapidly. You need your elbows to be facing outward, not downward. ;) But to each his own. Just pointing that out as a safety measure.
  14. SkookumPete
    SkookumPete Active Member
    Yeah, and with pointy chrome things sticking out everywhere. As much as I admire the cars of my youth, they were deathtraps.
  15. electriceddy
    Hands on a steering wheel position change quite frequently as demonstrated by this video:
    :D
    Jamas likes this.
  16. GPM432
    GPM432 Active Member
    I drive at what ever time it is but mostly one handed.LOL
  17. Vanryan
    Vanryan Member
    Our Toyota Highlander doesn’t heat up the top of the steering wheel. Personally I like that the Kona heats the whole thing.
    TheLight75 likes this.
  18. GPM432
    Skookum Pete This is my pointy ICE car New Paint Job April 2012 017 (Small).JPG New Paint Job April 2012 005 (Small).JPG no seat belt padded dash heated seats and heated steering wheel
  19. SkookumPete
    Not designed for pedestrian safety. I was thinking of the interior fittings, some of which were engineered to maim. ;)
  20. GPM432
    No interior safety at all.
