It wasn't clear if you physically disconnected the terminal to get the grease inside the connection, but that is essential of course.
Sorry to ask a silly question, but what type of grease do you use for this? Are you just putting it at the top of the strut or the other bolts as well?
Just the strut bolts ( passenger and drivers sides under the rubber cap), regular muti purpose grease: https://www.canadiantire.ca/en/pdp/motomaster-multi-purpose-grease-0280801p.html?rrec=true#spc Dielectric grease for the battery terminals. Be careful putting the plastic covers back on as the tabs bend, better to stick a screwdriver in the slots and guide them into place.
I'm intending to pull the entire cowl for a looksee at some point, maybe after we're past pollen season, because it's good to clean all that gunk out of there anyway. One goal is to get some mesh over the HVAC air intake to keep critters out, because unlike most cars, if you shut down with the intake flap in RECIRC mode it does *not* stay that way in the Kona, but deliberately opens to the fresh-air position. That is an open invitation to chipmunks from miles around to come party in the fan box and see how many acorns they can pile up in there. _H*
Surprised you haven't done that already I was thinking of a mesh in front of the air intake at the front (done nicely of course around the radar) to stop bugs/rocks from entering. Look forward to the write-up.
Updating this after a month-plus ... I finally did pull the cowl for a looksee, and did various block-off hacks. It was insanely easy, by comparison with the Prius. I probably won't have to do it very often, because the critical drain areas can be cleaned out through two convenient pop-off panels. _H*
I went and had a look with a flashlight (through the existing plastic cover) and am surprised (not favorably) at the wide open inlet. Thanks so much for the detailed write up and solution. BTW, did you pull the rubber caps over the struts just to have a look?
A picture from Reddit : Good reason to check connections periodically also make sure the grease is still doing it's job
Hi Interesting read and I am old enough to appreciate CRT's and what the are ....worst shock I received working as an electrician for 40+ years was while doing a Service Call at a Canadian Tire Gas bar from a stupid neon sign...brushed my bare arm across an exposed terminal...man that humbled me! It also reminded me of what one of my colleagues used to say when I was an apprentice..."there are old electricians, there are bold electricians but there are no old bold electricians..." RIP Joe Rudnisky! Mike
I'll never forget the old electrician sorting out fuse-box problems in an old house I lived in. I was shocked when I saw him walk from room-to-room sticking his finger into empty lightbulb sockets! Clearly, he knew exactly how much resistance his finger presented to those circuits. He didn't wash his hands just before the investigation phase of this job.
