Puppethead
I experienced no fogging at all. The air vents and fan operate while in green+ mode, blowing cold air into the cabin. Since humidity levels in the winter are in the 10%-20% range where I live there's very little moisture in the air. And the inside was as cold as the outside so there would be minimal condensation.@Puppethead how fogged up do your windows get?
Blowing air is the best way to clear fogging, regardless of temperature. I once had a VW Beetle with an oscillating fan attached to the dash to blow constant air on the windshield because it fogged really badly.
The other option is to open the windows a slight bit, so what moisture there is can escape. If in green+ there's no heat anyway so letting outside air in shouldn't make things less comfortable.
