I use and like the Chargepoint.
Our very own insideevs has an article on EVSEs.
https://insideevs.com/news/344002/charger-guide/
For me, it is without question to buy a quality, UL listed EVSE and make certain it is properly installed. At 32 amps, your car is almost certainly the single highest continuous amperage draw of electricity in your home when being charged and is definitely the single most expensive thing you ever have plugged in.
Sure enough. Some 6AWG wire, a breaker and receptacle, some conduit, and about 45 minutes of quality time with tools. What more could I ask of life?Agree, I use a Chargepoint, no issues. did the wiring myself. bought the pug in unit and installed a 6-50 receptacle.
While there is nothing wrong with Level 1 charging your Clarity, a Level 2 evse is actually 5.6% more efficient.I've had 3 PHEVs and have always used a regular standard wall socket. I usually time the charge to start at off peak 10P. Even with completely drained batteries they're always fully charged by 8A. Have never had any problems and saved on my electric bill.
I recently read somewhere that charging at Level 2 can lower the life of the battery quicker than charging at Level 1. I use a lot of lithium rechargeable batteries in my work and have found that a quick charge lowers the life of my batteries. When I charge them on a slow charge they seem to hold a charge longer.
I’d be interested to know where you read that. The only thing I’ve seen about the question of charge rate vs battery life is related to DC fast charging, something not relevant to the Clarity PHEV.I recently read somewhere that charging at Level 2 can lower the life of the battery quicker than charging at Level 1. I use a lot of lithium rechargeable batteries in my work and have found that a quick charge lowers the life of my batteries. When I charge them on a slow charge they seem to hold a charge longer.
Just included this link in a post in the "Was the battery ever charged..." thread but it also applies here:
https://electrek.co/2019/12/14/8-lessons-about-ev-battery-health-from-6300-electric-cars/
One of the conclusions the article draws from the data is:
"The use of DC fast-chargers speeds up the process of degradation, but there’s not much difference in battery health based on frequent use of Level 1 versus Leve [sic] 2 charging."
Here's a link to those results: https://ieeexplore.ieee.org/document/7046253
Granted, it is a very small difference and would take a long time to recover the cost of installing a 240v outlet and the Level 2 evse itself. In my case, it cost $250 to have an electrician install a 50amp breaker and NEMA 14-50 outlet in my garage. I paid $240 for a Level 2 evse.
I have run into situations where I get home from work with less than 30% charge and find out that I need to run some errands that evening that will exceed my remaining battery charge. With a 32amp Level 2 evse, I put ~ 4 kWh back into the battery in about 30 minutes.
@MrFixit is spot on.It's not just whether you are charging at Level 1 vs. Level 2. It is the rate that you charge relative to the battery capacity. If it takes you an hour to fully charge the battery, that is defined as a "1C" rate (1 x capacity). The highest charge rate possible with the Clarity PHEV is 30A @ 240V (7.2 kW). Since the total battery capacity is 17 kWh, this is a charge rate of only 0.42C (7.2 kW rate / 17 kWh capacity). I think you will find that this is considered a low rate, and it will not impact battery life...
In the scenario that you describe (maybe you are referring to power tools?) - Can you quantify your "quick charge" vs. "slow charge"? How long does it take to fully charge a battery in both of those cases? Knowing those relative charge rates could explain why you may experience a degradation while we wouldn't expect to see any with the Clarity even when using the maximum level 2 rate.
Is there a consensus as to what's best?
