Most who bought this year are too early to have any real maintenance come up yet but here’s some info I’ve accumulated:
-We can assume that with the majority of our driving being EV that some maintenance items will time out rather than come due from milage.
-We don’t know if the Maintenance Minder (MM) will use only HV miles or total miles to calculate oil change intervals. Obviously total miles would lead to unnecessary oil changes. Our owner’s manual does state that even if the MM does not give a code A, the oil/filter must be replaced at least every 12 months.
-Same scenario for brake fluid. Even though we hardly use the physical brake pads and rotors, manual says to change brake fluid every 36 months or with MM code 7. Pads and especially rotors may well be life time w mostly regen braking.
-Same scenario for engine coolant. MM code 5 or every 10 years which ever comes first (source: underhood sticker)
-Spark plugs are NGK Iridiums so I don’t expect MM code 4 to occur until 80-100,000 miles.
-Engine air cleaner will not be used up if MM tracks total miles for it. I’m doing 90/10 EV/HV, so my total miles would have to reach 150,000 just to get to the dusty conditions change milage of 15,000m. Again, we’ll have to wait a while to see what the MM does for this.
- Transmission fluid should track total miles since it’s used all the time. We don’t know what the MM trips at, but the mountainous/low speed accelerated change schedule is 47,400 m/3yr. So I wouldn’t expect a code 3 before then.
-And your MM trivia question of the day:
Why is there no Code 6 listed?
Because that is the code for changing the rear diff fluid on AWD Hondas.
I installed puzzle locks on the wheels and the correct torque for our lug nuts is 80 Ft/lbs. So don’t let the clowns at your local garage use an air gun set at who knows what force.
For to do tips, first thing is to get a coat of wax on it. Mine came w nothing on the paint at all. Beads up water nicely now.
Also, apply RainX to outside glass and wiper fluid and you’ll hardly ever have to use the wipers over 35-40 mph.
Keep front Honda emblem clean as that’s where radar sensor/emitter is located. More of a problem w icy conditions. Keep windshield area clean where camera is located for best Honda Sensing operation.
Try the wide/fish-eye option on the backup camera to partially compensate for not having rear cross traffic alert.
Be safe w the Honda Sensing. Realize it’s for driver ASSIST not self driving.
