What is this icon on dashboard?
  • Thread starter Thread starter Alex0913
  • Replies Replies 16
Alex0913
I don’t remember seeing it on, does anyone know? Do you have it on? Thanks in advance!
Thanks for the reply! This happened after getting the multiple warning lights after the charging station stopped charging the car for some reason. All of those went away on their own, but that one remained, so weird.
Yes, that is normal behavior after the charging error. It should reset (light will go out) after a day or two of driving.
Yes, this is the way most cars work now. The "check engine" or "MIL" (Malfunction Indicator Light) indicates that there are diagnostic codes that have been recorded. As it is yellow it is only a warning, not a problem. It generally resets after 24 hours or so.
All these reports of warning lights after using a public charger have me very leery of charging anywhere except at home! I have not used a public charger yet.
I used to get these warnings 2x per week when I used my work chargers. After the 097 software fix the car charges almost all the time without any issues (Clarity is a bit more sensitive then other EVs at my work) and I have not seen those warnings on the dashboard at all.
Sounds like you didn't bother to get the software updates. Take the car in and get the software updates. "Multiple warning lights" was fixed several months ago.
I hadn’t had that issue happening after charging it a public station so I went with the “if ain’t broke.....” but now I will take it in for sure, thanks everyone for your input.
I got that light a few times using my work chargers. If you have an OBDII you can clear that yourself.
My work chargers never charge back to full so I have just stopped using them. Now I just charge at home. It's sad because it's 60 miles round trip for me to work which means I spend at least some mileage a day in HV mode.
Just remember, you're still four times better than the idiots commuting in their F250 trucks on an mpg scale of betterness [emoji14]
Hahaha!! I USED TO BE THAT GUY! I have a 2006 Nissan Titan and I was spending 400 dollars a month on gas. Hence.....The Clarity....which I love.
In all fairness though....whenever someone needs something moved who do they call....the Clarity owner or the Titan owner?
True. I'm still hanging on to a 2001 CR-V for the occasional IKEA trip.
My work chargers would give me issues which would eventually result in the charging system problem error and check engine light. No issues after the software fix. So if you haven't gotten it yet, get the update and try again.
I took my Clarity to the dealer who said I have all the software fixes (this was in November) but I am still having the issue.
