Volvo EX60
  • Thread starter Thread starter navguy12
  • Replies Replies 42
  • Views Views 736
What improvements would you like for the interior lighting theme?
Will you get the Cross Country version if that's the only version with the bronze paint?
I’m not 100% convinced we had the conditions and settings correct to actually see the interior lighting theme as it is intended to be appreciated; I’m actually reviewing some of my questions, based on my test drive experience, via the online owners information/manual:
https://www.volvocars.com/us/support/car/ex60/
I will not consider the Cross Country version only because it doesn’t have a light interior theme; AFAIK it’s all dark themes.
That said, I would probably go for the EX60 white exterior and either live with it or wrap it in something “not black or grey”
I already dip test the brake fluid in my TM3 every two years for moisture; as well, I already change the air filter once every two years.
I also lubricate my brake calipers once every spring; I suspect the Canadian specification will probably include that as well.
At this point, there doesn’t appear to be any magic coolant that has to be flushed every five years…
