Using 12V Car Outlet In An Emergency
Steadfast
I have not seen this mentioned before but any EV can be used to provide power to your home if you have a battery or portable solar generator. You can simply charge the battery or generator with the 12V outlet in your vehicle and then run your home from the generator or battery. It's not the same as being able to plug directly into your vehicle but in the case of an emergency and having no heat or your food going bad, it is an option.
