Debating if it's a transmission or not is honestly kinda silly. It's all semantics. I consider the clarity to have a transmission because it is at the end of they day what translates engine power into useable power to the wheels. Even if it didn't have engine drive I would probably consider it a transmission for the same reasons. For all I care it could have a solar ionization reactor with energy links to ion engines in there, so long as input shaft come in and axle shaft come out, from the outside observer it is a transmission.It is now available as a two speed at least in the CRV so that does convert it to a real transmission. See third paragraph below.
- This configuration allows for the use of a larger and more powerful propulsion motor, which now has an increased torque output of 247 lb.-ft. (+15 lb.-ft.). It also maintains its 181 hp over a broader range of motor rpm, thereby improving response.
- The new propulsion motor uses new high-performance magnets that, as before, are made without heavy rare-earth metals. Internally, the motor uses a multi-ring structure that helps enable a higher peak motor speed of 14,500 rpm, an improvement of 11.5%. This higher motor speed also contributes to a higher sustained top speed capability for the 2023 CR-V hybrid models (Sport and Sport Touring) of 115 mph, 28% faster than its predecessor.
- The new side-by-side arrangement also enables the use of an additional direct-drive gearset with a new low-speed lockup clutch (deployed in CR-V only) allowing engine drive at urban speeds and supporting the ability for CR-V to tow up to 1,000 pounds, a first for the two-motor hybrid system.
- A high-speed lockup clutch is used in both CR-V and Accord, enabling a more relaxed driving environment at highway speeds by reducing engine rpm while also contributing to the new higher continuous top speeds.
